Old 28-02-2008, 11:43 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default 2 lan cards on 1 machine
iv connected 2 lan cards on the same machine but i cant them both to work together any ideas, both work individually
http://beingmanan.com
iMav is offline
Old 28-02-2008, 11:54 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: 2 lan cards on 1 machine
What are the IP settings for both? And how exactly do you want them to work?
infra_red_dude is offline
Old 29-02-2008, 12:00 AM   #3 (permalink)
dOm1naTOr's Avatar
PCI slot problem maybe
try one at a time on both slots and see if slot is workin fine.
There shudnt be any problem in using 2 or more lan cards. Do u use one for lan and other for net?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 29-02-2008, 12:19 AM   #4 (permalink)
iMav's Avatar
1 is for internet (broadband) so it has its own ip config & the other is for local network and therefore has its own ip, but when i connect the cable to it the network icon still appears with the red cross
individually both cards are working fine
iMav is offline
Old 29-02-2008, 12:21 AM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ Could we have all the details? IP/Subnet for each card, network topology?
kalpik is online now
Old 29-02-2008, 12:31 AM   #6 (permalink)
iMav's Avatar
edit: i got it to work, damn i just changed the ends of the cable i was using , damn thanks for the help anyways guys
iMav is offline
Old 29-02-2008, 01:00 AM   #7 (permalink)
dOm1naTOr's Avatar
oh is that correct???
i was thinkin both ends works same for cross cable ethernet.
Now can u explain which color coding for server and the client??[server as the one with internet nd client as one which shared the dns]
@iMav
ur siggy quote is hilarious
G3: XPS M1530 |
FZ 16.
Old 29-02-2008, 01:28 AM   #8 (permalink)
iMav's Avatar
@iMav
internet connection i think is straight cabling im not sure, the local network is cross cabled and now that i have setup realvnc thanks to charan's tutorial i have a headless chicken in the house
the siggy heheheh thank u
iMav is offline
new machine!! help!! varunprabhakar Hardware Q&A 10 12-07-2007 01:50 PM
Will Serious Sam 2 run on my machine? bukaida Gamerz 1 15-11-2006 01:10 PM
price of graphic cards graphic cards Varunnagwekar QnA (read only) 1 02-08-2005 06:02 PM
ASP.NET Machine A... gambit QnA (read only) 1 17-07-2005 05:40 AM
Old Machine Problems sachin_kothari QnA (read only) 2 06-01-2005 05:14 PM
- by c4u
