Old 28-02-2008, 12:30 PM   #1 (permalink)
Default Buying a laptop
Hi,
I want to buy a new laptop. My budget is 40-45k.
Please suggest me some....
I have searched the net and found Dell 1525 & Dell 1530 suiting my budget and requirements (formal gaming and programming). Other laptops in same range(sony,lenovo,ect) seems to have lower config wrt Dell.
Thanks in advance
purujitb is offline
Old 28-02-2008, 12:43 PM   #2 (permalink)
New
New's Avatar
Default Re: Buying a laptop
Slightly increase your budget and go for Dell 1520.Read the review of 1520 in "Review" section.
New is offline
Old 28-02-2008, 12:59 PM   #3 (permalink)
I checked the Dell site and compared 1520 with 1525.
At same configuration 1520=>Rs. 54k ; 1525=>Rs. 50k
The only difference was in the video card 1525 had X3100 whereas 1520 had nvidia 8600M GT.
So is nvidia worth 4k
purujitb is offline
Old 28-02-2008, 01:10 PM   #4 (permalink)
gowtham's Avatar
it definitely is. it can offload decoding videos from ur proc, so u can njoy HD vids and not to mention the jump in ur FPS in games!
But still, i would like it if u go for the xps m1530. its muchhhhhhhh better, trust me!
There is always a better way to do it. Go find it!
Thomas Alava Edison
gowtham is offline
Old 28-02-2008, 01:23 PM   #5 (permalink)
XPS M1530=>58k Too high.
I can at max stretch till 1520.
Other than Dell is there any other lapy in the same range??(better than 1520)
Also should I go for T5450 or T7250 the price difference is 5k
purujitb is offline
Old 08-12-2009, 10:52 AM   #6 (permalink)
The Revolutionary
thetillian's Avatar
Look for Dell Studio 15 (or) Acer Aspire 5738G these are the best ones which have a graphic card below 50K. At my city Acer Aspire 5738G comes with blue ray reader (not writer) price is something near to 45K.
"It Is Not The Position You Stand, But The Direction In Which You Look."
thetillian is offline
Old 08-12-2009, 09:38 PM   #7 (permalink)
Hi Guys,
I need help to buying my sis a laptop.
She mainly requires the laptop to do her work -->C, C++ , (SAP may be in near future). Her budget is 30K to 35K.
I found few good laptops like HCL ME LAPTOP B3863 --> Rs34K (net price) but i need your valuable suggestions
Guys please try to give reply soon
Thanks
karan_singh999 is offline
Old 08-12-2009, 10:00 PM   #8 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
plz check the date before making a post..... dont dig up old threads
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 08-12-2009, 10:09 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Originally Posted by karan_singh999 View Post
Hi Guys,
Thanks
my pick would be Acer 5738 for 35k-37k
desiibond is offline
Old 09-12-2009, 12:48 AM   #10 (permalink)
@ karan_singh999
if u want something cheaper then u can buy acer 5542g for around 32k
Old 09-12-2009, 12:56 AM   #11 (permalink)
Super Moderator
asingh's Avatar
DELL Inspiron is good. You can check it on their website. Interested in DELL, I can advice further.
---------- Post added at 12:56 AM ---------- Previous post was at 12:56 AM ----------
DELL Inspiron is good. If interested.. I can advice more.
asingh is online now
Old 09-12-2009, 11:13 AM   #12 (permalink)
Yes i hvae no probs with dell till the time it is out of her budget(that can be a small problemo)and she is able to do her work
Pls reply soon
Old 10-12-2009, 12:18 AM   #13 (permalink)
Super Moderator
asingh's Avatar
Dell(TM) Inspiron 14 Laptop ( S541001IN8 ) @ Rs.32,228.38 (Excluding Tax and Delivery)
Intel® Pentium® Processor T4300 (2.1GHz / 800FSB / 1MB Cache)
Genuine Windows® 7 Home Premium 64bit (English)
McAfee(TM) Security Center (Multi-Language) - 30-Day Trial Version
3GB (1X1GB+1X2GB) Dual Channel DDR2 SDRAM [Included in Price]
250GB 5400RPM SATA Hard Drive [Included in Price]
8X DVD+/-RW Drive with DVD+R double layer write capability, with Roxio Burn 1.0--For Win7
Intel(R) Graphics Media Accelerator X4500HD
Dell Wireless 1397 802.11b/g Half Mini Card
Dell Wireless 365 Bluetooth
Old 17-12-2009, 02:15 AM   #14 (permalink)
$%-Not Assembled Properly
check out
Acer's 3D-equipped Aspire 5738DG
its with in your budget and got 3-d
rrrmanish is offline
Help me in buying a Laptop!!! go4saket Laptops and Netbooks 12 04-08-2008 05:26 PM
Please help me in buying a laptop Adam Lee Laptops and Netbooks 2 23-07-2007 05:47 PM
Help In Buying Laptop monkey Hardware Q&A 1 04-10-2006 11:18 PM
Need help in buying Laptop!! nach p Laptops and Netbooks 1 18-09-2006 03:57 PM
Buying A Laptop er.darshan QnA (read only) 94 16-06-2005 12:50 PM
- by c4u
