Old 27-02-2008, 07:37 PM   #1 (permalink)
Traceur
zegulas's Avatar
Exclamation Screen gets blue.
Hi all,
Something weird is happening with my CRT display, it gets blue frequently. Once I just slapped it in frustration and it worked properly then for sometime, but now even slapping it doesn't help. In between it works fine for sometime, but then again it goes blue.
Please help me, I can't even watch movies properly and its hurting my eyes a lot!
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 27-02-2008, 07:39 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Screen gets blue.
check the back connectors (both ways-monitor and PC's VGA out),
if that doesnt work get it serviced-its a dry solder most probably
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 27-02-2008, 07:47 PM   #3 (permalink)
ayush_chh's Avatar
how old is you monitor?
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 27-02-2008, 08:43 PM   #4 (permalink)
New
New's Avatar
Same problem is happening in one of my friends pc.
New is offline
Old 27-02-2008, 08:58 PM   #5 (permalink)
Ethan_Hunt's Avatar
Dude don't aggravate the situation by hitting it constantly.It would lead to some internal damage which would cause it to malfunction completely later on.I used to do this with my Sony TV earlier but then one day got no picture out of it.
Some internal connectors must be loose.Get it checked by the hardware vendor ASAP.How long has it been with the monitor?
V for Vendetta
Ethan_Hunt is offline
Old 27-02-2008, 09:23 PM   #6 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Your computer [and monitor] is a non-living thing, despite all the sounds it makes. Non-living things DO NOT respond to oustside stimulus. Therefore, PLEASE, don't sap your monitor...
Homer: God bless those pagans.
ring_wraith is offline
Old 27-02-2008, 09:49 PM   #7 (permalink)
Traceur
zegulas's Avatar
Well the monitor is around 2 years old, but it displays the content very crisp, but only with a blue ting. Connections are perfectly OK.
zegulas is offline
Old 27-02-2008, 10:06 PM   #8 (permalink)
Ethan_Hunt's Avatar
Are you sure the connections are OK? Internal hardware is something we won't be able to diagnose.So it's better to get the hardware person to check the connections to the tube.
V for Vendetta
Old 28-02-2008, 08:55 PM   #9 (permalink)
ayush_chh's Avatar
pls specify the brand.
Old 28-02-2008, 09:08 PM   #10 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I thought you got a BSOD...
noise from the mobo or procy or GPU can cause such problems.
also, weakening picture tubes on TVs get pink colour. maybe monitors get blue colour.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 28-02-2008, 09:10 PM   #11 (permalink)
Alter Bridge=GOD
have u tried Degaussing it?
Old 28-02-2008, 09:16 PM   #12 (permalink)
Intel OCer
amitash's Avatar
one of my friends has tis problem...in his monitor the display almost totally goes off...i think he pressess the monitor downward or somethin like tat...
My site: collegeclassroom.org
amitash is offline
Old 28-02-2008, 09:18 PM   #13 (permalink)
Krazy_About_Technology's Avatar
I think you have a loose connector (or damaged). the connector of monitor gets loose sometimes for no reason. My old LG monitor got this problem. Please look at it, and dont try to repair or slap around, if you cant do it externally, give it to some repair center. monitors have a nasty habit, they can blast if tempered with badly, so please practice caution.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Blue Screen.....!!!!!!!!! swap_too_fast Software Q&A 7 15-11-2007 05:02 PM
Help me! Blue-screen george101 Hardware Q&A 6 29-10-2007 04:30 PM
Blue screen Nandkishor Kale QnA (read only) 7 18-09-2007 08:28 PM
Blue Screen Help naveen_reloaded QnA (read only) 5 25-11-2005 03:31 PM
blue screen sujeet2555 Software Q&A 4 15-11-2005 03:02 PM
- by c4u
