Old 26-02-2008, 08:17 AM   #1 (permalink)
Default System running below its Potential???
Please have a look a the Images and inform me if there is anyway i can get the system running to its full potential.
Any suggestions or tweaking steps will greatly help.
processor
Memory
Memory Module 1
Memory Module 2
This is the CPUZ report
Name :AMD Athlon 64 X2 5000+
Specification : AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
Core Speed : 2606.0 MHz
Multiplier x Bus speed : 13.0 x 200.5 MHz
HT Link speed : 1002.3 MHz
Stock frequency 2600 MHz
L1 Data cache (per processor): 2 x 64 KBytes, 2-way set associative, 64-byte line size
Memory Frequency 325.8 MHz (CPU/8)
Module 1 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Corsair
Module 2 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Corsair
krinish is offline
Old 26-02-2008, 08:52 AM   #2 (permalink)
Default Re: System running below its Potential???
ARe you looking for anOC solution here? Like how much max you can squeeze out?
In that case Post your Mobo Model and pC2-5300 isnt exactly a OC friendly Ram.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is offline
Old 26-02-2008, 08:54 AM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
which motherboard is that?
Your ram is 667 mhz-thats the dual channel frequency.its shown 333 only-thats ram cycle (frequency) and thats what CPuz is showing-its correct.
but the thing is-
if ur motherboard has 4 ram slots then u've inserted the rams wrong
Dual channel is enabled if u insert same rams (which u have) in same colored slots-like both rams in blue slots \black slots ,etc .that will make rams run in dual channel i.e. 667mhz in ur case
After that CPuz will show rams in either slot 2 and 4 or slot 1 and 3 -thats the correct order
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 26-02-2008, 11:32 AM   #4 (permalink)
but the thing is-
MOBO is Mainboard Model Gigabyte GA-MA69VM-S2.
I have inserted the RAMs in the same coloured slots, side by side, other two slots are of different colour.
I still feel the system very slow with soo much of RAM and processing power.
krinish is offline
Old 26-02-2008, 08:06 PM   #5 (permalink)
Alter Bridge=GOD
fresh install windows , run some benchmarks
Old 27-02-2008, 01:08 PM   #6 (permalink)
Any Sugegstions from the likes of choto (ChotoCheeta) and nvidia?
Please help me out guys.
krinish is offline
Running windows on a Linux Open Suse System ilugd Open Source 21 20-05-2007 10:29 PM
Firefox not running on system koolbluez Software Q&A 2 17-05-2007 02:54 PM
My new system is running slower compared to my previous system! instinct Hardware Q&A 12 13-10-2006 12:57 AM
bios showing cpu tmp 128 C and system running fine ?????? abhasbajpai CPU / Motherboards 2 07-10-2006 07:35 AM
my system stopping after 3-4 hours of running mousereddy Hardware Q&A 1 04-11-2005 12:55 AM
- by c4u
