Old 24-02-2008, 04:35 PM   #1 (permalink)
madmax_tt's Avatar
Default DVD reading problem
i have a LITE ON DVD writer and about 7 days back, it was acting strange.......the reading speed was very low...
when i purchsed it (ie, NOV 07) it was working very well and the DVD writing speed was also good. but now it takes about 2 mins even to autorun the DIGIT DVD ( but my sys is not slow )...
And when i burnt movie from my other SONY DVD writer to a blank DVD, and that DVD was also cannot be copied to HDD using the LITE ON, it gives an error...
IDE cable and everything is fine...
i use lens cleaning cd but it didnt help...
ive set the NERO CD\DVD DRIVE SPEED to maximum and 48X, but nothing...
wat coud be the problem?? it was 3 months only.....
there is a warranty but couldnt replace it bcoz ive lost it.....
madmax_tt is offline
Old 24-02-2008, 10:05 PM   #2 (permalink)
pushkaraj's Avatar
Arrow Re: DVD reading problem
1) Open notepad.
2) Copy the following code in it:
' Visual Basic Script program to reset the DMA status of all ATA drives
' Copyright © 2006 Hans-Georg Michna
' Version 2006-03-14
' Works in Windows XP, probably also in Windows 2000 and NT.
' Does no harm if Windows version is incompatible.
If MsgBox("This program will now reset the DMA status of all ATA drives with Windows drivers." _
  & vbNewline & "Windows will redetect the status after the next reboot, therefore this procedure" _
  & vbNewline & "should be harmless.", _
    vbOkCancel, "Program start message") _
  = vbOk Then
RegPath = "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\"
ValueName1 = "MasterIdDataChecksum"
ValueName2 = "SlaveIdDataChecksum"
ValueName3 = "ResetErrorCountersOnSuccess"
MessageText = "The following ATA channels have been reset:"
MessageTextLen0 = Len(MessageText)
SubsequentMisses = 0
Set WshShell = WScript.CreateObject("WScript.Shell")
For i = 0 to 999
  RegSubPath = Right("000" & i, 4) & "\"
  ' Master
  Err.Clear
  On Error Resume Next
  WshShell.RegRead RegPath & RegSubPath & ValueName1
  e1 = Err.Number
  Err.Clear
  On Error Goto 0
  If e1 = 0 Then
    WshShell.RegDelete RegPath & RegSubPath & ValueName1
    On Error Goto 0
    MessageText = MessageText & vbNewLine & "Master"
  End If
  ' Slave
  Err.Clear
  WshShell.RegRead RegPath & RegSubPath & ValueName2
  e2 = Err.Number
  On Error Goto 0
  If e2 = 0 Then
    WshShell.RegDelete RegPath & RegSubPath & ValueName2
    On Error Goto 0
    If e1 = 0 Then
      MessageText = MessageText & " and "
    Else
    End If
    MessageText = MessageText & "Slave"
  End If
  If e1 = 0 Or e2 = 0 Then
    WshShell.RegWrite RegPath & RegSubPath & ValueName3, 1, "REG_DWORD"
    On Error Goto 0
    ChannelName = "unnamed channel " & Left(RegSubPath, 4)
    ChannelName = WshShell.RegRead(RegPath & RegSubPath & "DriverDesc")
    On Error Goto 0
    MessageText = MessageText & " of " & ChannelName & ";"
  Else
    SubsequentMisses = SubsequentMisses + 1
    If SubsequentMisses >= 32 Then Exit For ' Don't search unnecessarily long.
  End If
Next ' i
If Len(MessageText) <= MessageTextLen0 Then
  MessageText = "No resettable ATA channels with Windows drivers found. Nothing changed."
Else
  MessageText = MessageText & vbNewline _
    & "Please reboot now to reset and redetect the DMA status."
End If
MsgBox MessageText, vbOkOnly, "Program finished normally"
End If ' MsgBox(...) = vbOk
' End of Visual Basic Script program
3) Now save this file as "Resetdma.vbs" with the quotes and run the file.
4) It will ask you to reboot your computer. Reboot it.
That should solve your problem
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 24-02-2008, 11:03 PM   #3 (permalink)
Default Re: DVD reading problem
I am also getting an error with the DVD Drive. When i run a DVD movies, Games or anything it is working ok, but when i insert a CD on a DVD Drive it is shown me the error. I had try many other CD's but they are all giving an error
Please help me. I am using WinXP.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 25-02-2008, 08:27 AM   #4 (permalink)
pushkaraj's Avatar
^^what error do u get?
Old 25-02-2008, 09:38 AM   #5 (permalink)
Sorry now the problem was solved byt his method
Right-Click on the drive w/ the problem
Properties
Recording Tab
and then check the "Enable CD Recording On This Drive" box.
Thanks
boosters is offline
Old 27-02-2008, 01:34 PM   #6 (permalink)
madmax_tt's Avatar
problem solved........ thanks
problem on reading DVD on LG DVD combo bisu_016 QnA (read only) 2 10-07-2007 11:53 PM
Problem reading PM startmenu QnA (read only) 5 22-02-2006 11:09 PM
Problem Reading Last Session of CDR dragonball QnA (read only) 4 18-12-2004 12:50 PM
Problem Reading Files In SONY CDRW dragonball QnA (read only) 6 22-10-2004 05:07 PM
