Your mobo is based 650i sli chipsetif i am not wrong.
This mobo will easily handle 4 gigs in dual channel mode ( supports upto 8 gb )
There is no point to waste your remaining 2x1 gb modules as you will not upgrade in the near future. But if you want to upgrade then go for 2*2 gb ddr2 800 mhz ram modules.
There is no enough in the world of ram as it is the express way of your system. Future Multimedia applications will benefit from a large amount of ram.
You will also need 64 bbit edition of winxp or winvista to get all the juice from 4gb ram as 32 bit editions of both xp & vista only supports 3.23 gb of ram.
Originally Posted by ring_wraith
Y
BTW. you do know that you will have to go to a 64 bit OS right? 32 bits cannot support 4 gigs of RAM.
it is not true that 32bit oses can not handle 4 gb ram Only consumer level 32 bit oses like xp & vista can not support more than 3.23 gb of ram.
For example 32 bit edition of windows 2003 server enterprise supprts 32gb of ram & data center edition can handle 64gb of Ram.
http://www.microsoft.com/whdc/system...AE/PAEmem.mspx
