Old 24-02-2008, 12:47 AM   #1 (permalink)
joy.das.jd
Posts: n/a
Default Suggest a Motherboard
I want to upgrade my motherboard+ram+Graphics card. My budget is around Rs 7000 to Rs 8000. Now I want a motherboard which should be of microATX form factor only (as i have a small cabinet). I have decided to go for the XFX 630i - 7150 motherboard and 2 Gb of ddr2 RAM. Now i am very confused about the graphics card . Pls suggest a good Graphics card in about Rs 3000. I will be running the games on 1024x768 resolution only and even dx9 cards are welcome as i will be running windows XP only. The details of my processor are as following
Processor 1 (ID = 0)
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Pentium 4 515
Codename Prescott
Specification Intel(R) Pentium(R) 4 CPU 2.93GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID F.4.1
Extended CPUID F.4
Core Stepping E0
Technology 90 nm
Core Speed 2932.2 MHz (22.0 x 133.3 MHz)
Rated Bus speed 533.1 MHz
Stock frequency 2933 MHz
Instructions sets MMX, SSE, SSE2, SSE3
L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 1024 KBytes, 8-way set associative, 64-byte line size
Urgent help required.....
One more question. What is the price of a 2Gb pen drive in kolkata?
Old 24-02-2008, 12:51 AM   #2 (permalink)
j1n M@tt's Avatar
Default Re: Suggest a Motherboard
plz post ur request in this dedicated thread....http://www.thinkdigit.com/forum/show...452#post756452
and u don't hav to explain abt ur processor so much, everyone can understand just by telling its name 'P4 515'
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 24-02-2008, 01:08 AM   #3 (permalink)
joy.das.jd
Posts: n/a
Thank you. I will post it there..
suggest a gud motherboard fun2sh Hardware Q&A 21 25-11-2007 06:00 PM
Suggest a motherboard godsownman Hardware Q&A 14 30-07-2007 06:52 PM
Suggest a motherboard catchjaga CPU / Motherboards 3 11-08-2006 11:45 AM
AMD motherboard !!!! Plz suggest sidewinder CPU / Motherboards 1 26-10-2004 12:00 AM
