Old 23-02-2008, 01:40 PM   #1 (permalink)
Sangeet Premi
2kewl's Avatar
Default RAM Query!
Hey Guys!
I recently installed a 512 DDR 266 alongside my 256 DDR333. I thought it shouldn't be a problem as the both should run at 266. Howver my 266 RAM is OC at 333 and as a result Im getting errors with many programsn and also frequent BSOD's.
Is there a way I can make both the RAM's run at 266 Mhz? I guess, that should solve the stability issues
2kewl is offline
Old 23-02-2008, 02:11 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: RAM Query!
Check the RAM frequency in your BIOS and manually set it to 266 (actual 133mhz)
Pathik is offline
Old 23-02-2008, 02:42 PM   #3 (permalink)
Sangeet Premi
2kewl's Avatar
I did check BIOS! No option to change memory frequency.
My mobo is Intel D845GVSR and BIOS is Intel Corp. VA84510A.86A.0030.P10.0402160229 02/16/2004
2kewl is offline
Old 23-02-2008, 07:54 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
That's odd! Check carefully. Your Bios should have that option
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 23-02-2008, 09:17 PM   #5 (permalink)
Sangeet Premi
2kewl's Avatar
Found it and changed! Seems fine now
Thanks Guys!
2kewl is offline
Old 24-02-2008, 07:22 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ Rest in peace pal
topgear is offline
SLI Query? sabret00the Hardware Q&A 27 12-08-2007 04:40 PM
Query BHANU SS QnA (read only) 2 05-06-2007 10:52 AM
query about n70 and n73 dumbledore11 Mobiles and Tablets 6 10-10-2006 12:57 AM
c2d query ramana321388 QnA (read only) 8 09-10-2006 08:25 PM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
