Old 23-02-2008, 11:06 AM   #1 (permalink)
sg1
On a quest for knowledge!
sg1's Avatar
Question Ram Compatability
When I purchased my latest Mobo, I was told that it would support either DDRII OR DDR (dual channel) but NOT DDR and DDRII at the same time, However after visiting AsRocks website it says that it supports DDR AND DDRII ?? Does this mean I can run both at the same time or not?
I don't want to attempt it unless it will work but if I did try it, what would be the worst that would happen? Just boot failure I would guess!!
Has anybody tried it?
Ps: I know I've been away for a while but I hope to be spending more time online now that my little boy is better (so look out Gigacore!!! )
If it aint broke, then don't try to fix it!!!! :)
sg1 is offline
Old 23-02-2008, 11:11 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Ram Compatability
Hello Sir, Glad to know that your son is OK but just a personal question, as what went wrong with the kid ??
Sorry You cant, its iether DDR or DDR-II as both wont run at a same time
Plenty of BEEEEEEPs would follow but you should not try this
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 23-02-2008, 11:27 AM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
na, you can't use DDR and DDRII at the same time in coz configuration.
Gigacore is offline
Old 23-02-2008, 11:34 AM   #4 (permalink)
sg1
sg1's Avatar
Oh nothing too serious, he just wasn't putting on any weight since 6 weeks old and they didn't know what the problem is. He's now on a very high calorie/fatty milk product called Infatrini which is a formula to help with weight gain in young children and he seems to be responding well PS: thanks for asking
I thought that would be the case
OOHH go on please
Thanks for answering my query, I should have known the answer really as I build and repair PC's quite a bit, but this was just something I had never attempted with a Hybrid Mobo before Still.... you learn something new everyday
sg1 is offline
Old 23-02-2008, 06:20 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
DDR and DDR2 have different structure, so cant fit DDR2 RAM chip on a DDR supported motherboard, and vise versa.
ravi_9793 is offline
Old 23-02-2008, 08:18 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
^^^ You are all confused. His board apparently has both DDR an dDDR2 slots. He's asking whether he can use one stick of DDR and one stick of DDR2 in tandem. And the answer is: No, as answered
infra_red_dude is offline
Old 23-02-2008, 10:55 PM   #7 (permalink)
Rebooting
where ?? did my reply suggested i am confuse
rebooting
ChotoCheeta.com
Old 24-02-2008, 01:15 PM   #8 (permalink)
Wire muncher!
^^^ No Saurav. My reply was for Ravi, not you. You've clearly understood and explained it to the OP
Old 25-02-2008, 04:25 AM   #9 (permalink)
sg1
sg1's Avatar
^^^ He's asking whether he can use one stick of DDR and one stick of DDR2 in tandem. And the answer is: No, as answered
Actually I was thinking of using two sticks of each when I posted the question
sg1 is offline
Old 25-02-2008, 09:20 AM   #10 (permalink)
Ethan_Hunt's Avatar
I don't understand why Askrock advertises their motherboards in such a fashion that it confuses everyone.
I remember they had brought up a Hybrid motherboard which had both AGP & PCI-E support way back.Not sure what happened but nevethless people were still fascinated.By the looks of the above motherboard mentioned it seems to be one of those classic examples.
@sg1:Using 2 memory stick of different technology simultaneously is a no go.Both have different frequencies & configuration which they operate on & hence with both it won't be able to boot at all.No damage to the hardware as such.
V for Vendetta
Ethan_Hunt is offline
Old 25-02-2008, 10:31 AM   #11 (permalink)
Wire muncher!
Yeah... one or two.. How does is matter? Point is that you wanna use both the techonologies together. The result would be that your computer would prolly not boot at all. But you can't use them in tandem. Thats for sure
Old 26-02-2008, 05:03 AM   #12 (permalink)
sg1
sg1's Avatar
Originally Posted by allwyndlima View Post
I don't understand why Askrock advertises their motherboards in such a fashion that it confuses everyone. .
I know exactly what you mean Thanks guys(time to upgrade my CPU instead )
sg1 is offline
Compatability of a Power Supply ( SMPS) with a home UPS Big-G Hardware Q&A 4 29-08-2007 11:29 PM
DLink DI-524 compatability svgreatest QnA (read only) 1 09-08-2007 08:34 PM
vista compatability prob with razr v3i and n70 krrrish Mobiles and Tablets 7 19-06-2007 12:19 AM
MOTHERBOARD compatability 4 duel core prosscer... sreenivasj Software Q&A 5 09-04-2007 06:18 PM
