Old 22-02-2008, 06:00 PM   #1 (permalink)
ayushman9's Avatar
Question Max specs supported by p5b-mx
Hi friends , I want to known about the MAXIMUM specs like processor type and speed ,size of rams ,agp support etc by Asus P5B-MX/WIFI-AP.
Can it's bios be updated or is no longer supported?
What will be suitable alternative to the board if one want's a motherboard within the same prize but higher future compatibility.
There is No Dark & Light side of Force . There always has been,always will be & always has been,One & Only Ayushman
ayushman9 is offline
Old 22-02-2008, 06:21 PM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: Max specs supported by p5b-mx
u can use an E6600, or any other 1066Mhz FSB processor, it will support. (not sure about quad-core, maybe it does not support quad core)
667Mhz 4Gb memory
PCI-Express
I dont think asus will be releasing anymore BIOS for the board, so it is what it is.
Kniwor is offline
Old 22-02-2008, 10:41 PM   #3 (permalink)
ayushman9's Avatar
Cool Re: Max specs supported by p5b-mx
well the website once said it support quad core not extreme ,so i am confused.
Old 23-02-2008, 11:28 AM   #4 (permalink)
Learner
Kniwor's Avatar
Then it does, but mind it, it will not support 1333FSB, don't think that if u put in a 1333FSB processor it will run it at 1066FSB, the board DOES NOT even boot.
(I don't know if the new BIOS allows it, so u're gonna have to check that)
Kniwor is offline
Old 23-02-2008, 07:19 PM   #5 (permalink)
ayushman9's Avatar
Smile Re: Max specs supported by p5b-mx
well where can i get list of processors having 1066MHz or the fsb you listed .
Explanation about specs for RAM rohitjosh Hardware Q&A 1 09-05-2007 09:47 PM
New specs for next-gen Blu-ray players nepcker Technology News 1 07-04-2007 04:32 PM
Specs for a new comp guitarfreak Hardware Q&A 7 04-12-2005 09:12 PM
LOW Specs champ_rock Open Source 8 13-10-2005 09:37 PM
ATI R520 Specs leaked gxsaurav QnA (read only) 11 18-02-2005 12:14 AM
