Old 21-02-2008, 06:27 PM   #1 (permalink)
Default cmos problem!!!
i have a pc, with msi mobo.
and its been an year since i got it..
but recently for the apst 3 months, i m facing a strange problem with it,.
i set the cmos settings and everything,, it works for 2-3 days, very well..but suddenly after 2-3 days, the cmos resets...back...2 default,,,,, all the date adn time and rest of the things go away..even the admin password in cmos goes away....
i even updates my mobo with the latest cmos, 2 overcome the problem, but the same....
wots the problem pals....
cause if the prob was the battery, then the mobo wouldnt have even saved the settigns 4 2-3 days.....
thanx
TDW {RES}
The Day Walker! is offline
Old 21-02-2008, 06:31 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: cmos problem!!!
it depends how weak the battery is .change it and then see
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 22-02-2008, 06:42 PM   #3 (permalink)
have changed the battery...
will check it out now... will take 3-4 days....
thanx
angel
Old 22-02-2008, 11:14 PM   #4 (permalink)
The Unknown's Avatar
clock battery is the culprit. I had the same problem recently. Changing the battery solved it.
KDE on ArchLinux
The Unknown is offline
strange problem with CMOS battery ondemandemails Hardware Q&A 4 22-11-2007 12:14 AM
CMOS problem... ComputerUser QnA (read only) 2 17-08-2007 08:28 PM
CMOS problem...? LEARNER_LEARNER Hardware Q&A 7 14-12-2006 11:00 AM
RAM or CMOS problem....?? hard_rock Hardware Q&A 9 30-09-2006 03:20 PM
CMOS problem mkpaul QnA (read only) 4 24-07-2005 12:23 AM
