19-02-2008, 11:04 AM
Living to Succeed
a new machine for 3d and games
I want to upgrade my machine and the main purpose will be 3D design and rendering and Also latest game play with full features on.
i can invest around 40000-50000 on this.
Things i want to buy are:
a Motherboard (with wifi)
Processor (quad core or core 2)
Ram (preferable 4GB or more)
Graphic card ( 512MB or 2 Sli)
cabinet and smps
can some one suggest me a good combination.
i will also buy a Monitor if possible. I have a 17" Samsung TFT which i can sell and buy a 19" or 22" Dell or samsung monitor... Please also suggest on that
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
19-02-2008, 11:11 AM
Alter Bridge=GOD
Re: a new machine for 3d and games
Q6600=11500
MSI 8800 GT OC=13500
Cooler MAster Cabby + 460W CM SMPS (separate) = 5000 , around 4k if u buy a cheaper cabinet
4 GB Ram = 4000 ,say
A Wifi Mobo = Asus P5K Deluxe Wi FI = 13000
Total = 47000
Dell 22'' = 13000
Apple Macbook Pro 17 :cool:
20-02-2008, 09:48 AM
Living to Succeed
Originally Posted by nish_higher
Q6600=11500
Total = 47000
Dell 22'' = 13000
what is the difference between GTX, GTS and GT in 8800 graphic cards... and believe me i have never done OCing so am not sure whether i will do it or not
20-02-2008, 10:27 AM
Rebooting
rebooting
ChotoCheeta.com
20-02-2008, 01:21 PM
Intel OCer
motherboard:asus P5K-delux wifi-10500Rs
proccessor-Q6600 (quad core)-10500Rs
RAM-corsair XMS 2 2x2GB-4500Rs
Graphics card-Nvidia GeForce 8800GT-12500Rs
cabinet-Antec 900(5500Rs) or cooler master mid tower cases-4000Rs
460W cooler master SMPS
total=45000-50000Rs
in graphics cards GTX>GT>GTS
but the GT is really good value....nearly matches the GTX
20-02-2008, 05:09 PM
Living to Succeed
total=45000-50000Rs
Are u sure i can get the Corsair ram that cheap.. i heard 4gb of that will cost me around 12000...
also will 460w smps be sufficient... i will be having 3 hdd 1dvd writer running (might be one extra fan)
20-02-2008, 05:15 PM
-----ATi-----
460w smps may not be enuf for that config.
Get atleast 500W.
And corsair rams are available for that price. There are modules which are even more expensive
http://twitter.com/akshayms
20-02-2008, 05:58 PM
Living to Succeed
total=45000-50000Rs
I have 1 sata hdd, 2 normal HDD and one DVD writer... as i read the motherboard specifications i can use only DVD and one writer and 6 sata hdds... i think there is only one IDE slot ( i think i named it right)
20-02-2008, 07:01 PM
Alter Bridge=GOD
Thats not high end ram,its a high-mid end.+ u really not spend 6k on a cabinet if it doesnt matter.Cooler master cabby + PSU 460W = 5.5k max
and
P5K DLX Wi-Fi costs 13k not 10.5k
Source-
http://www.theitwares.com/motherboards/motherboards.htm
20-02-2008, 10:21 PM
At Hell's Disq
better go in for a X48 chipset based mobo by Asus.
21-02-2008, 01:14 AM
Living to Succeed
How many NON SATA HDD can i use on this Mobo...
21-02-2008, 10:09 AM
Alter Bridge=GOD
^ 2 ,
some boards also come with 2 pata ports so 4 in that case,till u have a PATA Optical device also
21-02-2008, 12:00 PM
At Hell's Disq
most of the new mobos support only upto 2 pata/ide devices,but if u want to use more then 2 ide devices then use ide to usb converter.
21-02-2008, 12:54 PM
Living to Succeed
How many IDE device does asus P5K-delux wifi supports...
21-02-2008, 03:14 PM
At Hell's Disq
^^^ only 2 ide devices.it has only 1 pata port
21-02-2008, 03:25 PM
Living to Succeed
any suggestion of same level board with 2 pata slots
21-02-2008, 03:36 PM
Alter Bridge=GOD
no, all others are without wi-fi then.its better to get a new SATA DVD writer
21-02-2008, 05:05 PM
Living to Succeed
bad luck for me... is there no option
21-02-2008, 05:22 PM
#19 (permalink)
Alter Bridge=GOD
not a thing above 10k has 2 IDE Slots
i once had P5N E SLi - it had 2 although i'd never recommend that board--big stability issues
Consider my idea of getting a IP 35 PRO without Wi-Fi and get a wifi router or stick with what i told u earlier..none of this will solve ur PATA problem though--the best solution is a SATA writer.
21-02-2008, 09:50 PM
#20 (permalink)
At Hell's Disq
u can always use ur dvd writer as an external dvd writers by connecting it thru usb.
22-02-2008, 12:24 AM
#21 (permalink)
Living to Succeed
what is the best motherboard without a wifi...
22-02-2008, 03:39 AM
#22 (permalink)
At Hell's Disq
Abit IP35-Pro or Abit IX38-Quad GT
22-02-2008, 09:22 AM
#23 (permalink)
Alter Bridge=GOD
Abit IP35 Pro would be better than IX Quad bcoz of its VFM and becoz u are not an extreme overclocker
22-02-2008, 10:22 AM
#24 (permalink)
Living to Succeed
i liked Abit IP35 Pro ... but any other option with SLI featurre as i want to upgrade to 2 Graphic card in future
22-02-2008, 10:27 AM
#25 (permalink)
Alter Bridge=GOD
in that case just 3 boards--XFX 680i LT SLi (very good for u~10k) ,Asus P5N 32E SLi or XFX 680i (both for same price~13k)
22-02-2008, 10:39 AM
#26 (permalink)
Why do u only want sli?? u can think of crossfire also. Ati has released the HD3XXX series which is more VFM than NVIDIA cards.
About motherboards, I dont think the mobos mentioned above will support 45 nm proccys from Intel. A bios update may do the trick but please be sure before buying. Then ur motherboard will be future proof.
U may even think of Spider Platform with Phenom processor + X38 chipset + HD3XXX series vga.
It has been proved already that X38/P35 chipset is far better than NVIDIA 780I Sli chipset.
DOTA is really addictive :D
22-02-2008, 10:44 AM
#27 (permalink)
Alter Bridge=GOD
dude these boards are Penryn Ready and BIOS update is not a trick! its just an update and nothing more.even X48s require bios updates. + he needs to wrk on 3d so its better that he gets a Q6600
22-02-2008, 10:56 AM
#28 (permalink)
Ok the boards are Penryn ready.
Spider platform can increase 30% performance.
Even in X38 chipset boards, there are two TRUE 16X PCI-E 2.0 slots for crossfire. Hence, Crossfire can be a better option than SLI.
22-02-2008, 11:07 AM
#29 (permalink)
Alter Bridge=GOD
SPider platform can increase upto 30% performance when comared to a non SPider AMD config
25-02-2008, 09:52 AM
#30 (permalink)
Living to Succeed
i am still confused...
which motherboard to go for...
what is better
Core 2 Duo3.0 GHzE6850-(4MB L2 cache 3.0Ghz 1333MHz)
Core 2 Duo2.66 GHzE8200-(6MB L2 cache 2.66Ghz 1333MHz)
Quad Core Q66002.4 GHzQ6600 - (8MB L2 cache 2.4Ghz 1066MHz
Quad Core Q67002.66GHzQ6700 - (8MB L2 cache 2.4Ghz 1066MHz
and can i install 4X2GB ram in the motherboard
