Old 18-02-2008, 03:59 PM   #1 (permalink)
Digit Addict
suyashpandit's Avatar
Red face My PC GONE!!!!!!!!!!!!!!!!
Hey guys i have 5 PC and 1 Lappy
one of my PC (its Compaq) is stopped working...
i used it at night but when i trying to open it the power is staying for 1/2 sec. and power off
my PC is out of warranty Except MotherBoard
tell me is my mother board is Gone or some other thing?
if MB gone then it will replace.. i am scared that my processor is ok or not!!
tell me which hardware can cause this prob..
suyashpandit is offline
Old 18-02-2008, 05:06 PM   #2 (permalink)
Boy Waiting To Be A Man!!
kayos's Avatar
Default Re: My PC GONE!!!!!!!!!!!!!!!!
come on now .. title suggested as if somebody stole ur pc...
try putting some sensible title rather than trying to get attention with all the "!!!!!!!!!!!!!!!!!!!!!!"
most probably its ur smps .. check that if the power supply is ok ..
as within overnighjt procy fail is not high probability...
With No Power Comes No Responsibility !!!
-Clark I
kayos is offline
Old 18-02-2008, 06:31 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
clean both the ram and the ram slots.
hellgate is offline
Old 19-02-2008, 07:11 AM   #4 (permalink)
The Transcendental
dead proccie...RIP proccie
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 19-02-2008, 12:28 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ how can be so sure that proccy is dead???
it cud be anything.probable chances r that SMPS is gome kaput or moisture in ram.
hellgate is offline
Old 19-02-2008, 12:45 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
open the cabinet and see if there are any signs of any component being burnt.
Try to run your computer with a different SMPS
http://twitter.com/akshayms
nvidia is offline
Old 19-02-2008, 08:51 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
Change ur smps ie psu. also check ur ups if U have any.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-02-2008, 10:37 PM   #8 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Smell ur cabinet if something is fried!
Check if power is coming to Motherboard and since u have 5 PC, then change the PSU and see it problem remains!
Dude people in the world owns only one PC( including me) but u have "FIVE"!!!!
U can do so much by yourself!
Just do it!
keith_j_snyder2 is offline
Old 19-02-2008, 10:41 PM   #9 (permalink)
The Transcendental
Sure i am not sure
Can be mobo capacitor syndrome, can be psu, can be processor, can be ram, can be bios, can be nb, can be faulty wires.
I just happen to have suffered a similar fate with a dead proccie .
Old 19-02-2008, 10:48 PM   #10 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
I don't know much much but when I had experienced such thing, the culprit was a internal TV tuner card. Just try removing all the addon-cards(if any) and try.
Also, there may be some dust issues in RAM. Try cleaning the slots. And since you have many RAMs, try if one from another system works!
गीक होना माँगता
victor_rambo is offline
Old 21-02-2008, 06:36 PM   #11 (permalink)
Digit Addict
my MB is Faulty and its in warranty so its gone to replace
thanks for ur support
