Old 18-02-2008, 02:48 PM   #1 (permalink)
Good Boy
george101's Avatar
Exclamation Help regarding hdd and pendrive!!!!
Hi guys than for all the help u hav given me so far...... i want to get myself a 250/320 gb hdd and a 8gb pendrive... which one shud i opt for??? wats d price for the hdd and pendrive??? which is better transcend or scandisk???
george101 is offline
Old 18-02-2008, 03:46 PM   #2 (permalink)
smile's Avatar
Talking Re: Help regarding hdd and pendrive!!!!
Seagate Hdd and Transcend pendrive always good
SR
smile is offline
Old 18-02-2008, 04:35 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: Help regarding hdd and pendrive!!!!
Seagate or WD HDD. and A Corsair Voyager GT.
Pathik is offline
Old 18-02-2008, 07:14 PM   #4 (permalink)
pushkaraj's Avatar
Arrow Re: Help regarding hdd and pendrive!!!!
Any particular reason for suggesting the Corsair voyager GT???
Check this link -> http://www.theitwares.com/usbprods/usbprods.htm
ITWARES quotes the price of 8 GB Corsair voyager as 2200 whereas the GT version costs 6600
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 18-02-2008, 07:23 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Ah.. My mistake.. GEt the Normal Voyager.. You can get the 8gb for 1.8k
Pathik is offline
Old 18-02-2008, 07:56 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
8GB Transcend V10 -> 1.6k
amazing transfer speeds.i'm using it and its far better than my previous 4GB Sandisc.
hellgate is offline
which is the best pendrive? max_demon Hardware Q&A 44 06-12-2009 07:30 PM
Pendrive raj.singla Hardware Q&A 15 18-12-2007 09:27 PM
Suggest A Pendrive kerthivasan QnA (read only) 1 09-05-2007 07:33 PM
very slow pendrive mazy Hardware Q&A 4 14-02-2007 01:55 AM
PenDrive Problem the.kaushik QnA (read only) 2 06-02-2007 03:31 AM
