Old 17-02-2008, 10:02 PM   #1 (permalink)
Default PC restarting with a click sound
Hi,
My old PC is restarting by itself after 1-2 hours of operation after a click sound. How can I diagnose the problem? It is a 2.53GHz Sempron.
tech_lover is offline
Old 17-02-2008, 10:35 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: PC restarting with a click sound
Diagnose!!!!! Run and back up all your data. It may be a sign of an impending head crash.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 17-02-2008, 11:03 PM   #3 (permalink)
I assume you have Windows. Use some tweaking utilities like ‘Customizer XP’ to ensure that option in registry “Automatically restart Windows when Explorer crashes” is disabled.
After this if the problem goes away… it most likely was a software (OS) problem.
Else one or the other hardware is malfunctioning could be right from SMPS to Motherboard. As you have indicated it’s an old PC, most likely some hardware is on verge of giving up.
patkim is offline
Restarting Windows Without Restarting Your BIOS (Vista or XP) marulez Technology News 14 23-08-2007 01:19 AM
Right Click = Left Click emailaatif786 Hardware Q&A 6 26-03-2007 02:48 PM
piercing sound from pc when restarting Ramakrishnan Hardware Q&A 15 08-07-2006 12:24 PM
XP Pro keeps restarting! Please help! arko Software Q&A 2 29-10-2004 12:44 AM
