Old 16-02-2008, 08:48 PM   #1 (permalink)
Default Querries about PC usage
I have a PC with C2Q Q6600,2*2GB DDR 2 RAM,8800 GTS 512 MB G92 SLI.
I have MTNL 256 kbps unlimited plan.I DL a lot and i have to keep my pc on for long hours (10+ hours continously).Is it harmfull for my pc??i mean will there be any issues if i keep doing this??
No stupid replies please
SunnyChahal is offline
Old 16-02-2008, 08:56 PM   #2 (permalink)
pushkaraj's Avatar
Default Re: Querries about PC usage
IMHO, there should not be any problem. However, if you want, you can check the hard disk and processor temperature through hardware monitoring softwares like Speedfan whenever you feel that the pc has been running for a long time.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 16-02-2008, 08:57 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
What SMPS do you have? It should be robust enough to take long hours of operation.
I too download a lot, but I do it on OpenSuSE. The biggest advantage of using linux for long hours is you do not need an antivirus or antispyware running in the background. So your system has less work. And if you use fluxbox, you can reduce the burden still further.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 16-02-2008, 08:58 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
If you are worried about heating issues, then get a good cooler for your comp and add an extra fan in the cabinet.
http://twitter.com/akshayms
nvidia is offline
Old 16-02-2008, 09:02 PM   #5 (permalink)
i have coolermaster power 850 pro with a big fan.
Old 16-02-2008, 09:05 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
^^In that case you dont have to worry about the PSU
Just add an extra fan in the cabinet.
nvidia is offline
Old 16-02-2008, 09:06 PM   #7 (permalink)
already there are 1-2 fans!
Old 16-02-2008, 09:08 PM   #8 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
you can build a download box for as low as 5k or so and it will be really power-saving.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 16-02-2008, 09:10 PM   #9 (permalink)
^^i have no plans to buy another box coz i already got 4!
Old 16-02-2008, 09:26 PM   #10 (permalink)
TechTin.com
ravi_9793's Avatar
Just pay attention to cooling..and nothing else.
keep room tem. normal......
Add another fan to cabinet.
Check SMPS, cabinet and Processor fan regularly.
Thats all...nothing more for 10 hrs work daily.
I keep my PC working for more than 12 hours a day
ravi_9793 is offline
Old 16-02-2008, 09:27 PM   #11 (permalink)
pushkaraj's Avatar
IMO, with a good antivirus running in the background, and with hard disks staying below 40-45C, there should not be any harm to the pc.
Old 16-02-2008, 09:34 PM   #12 (permalink)
i have AVG av but dunno abt HDD temps
Old 16-02-2008, 09:42 PM   #13 (permalink)
dOm1naTOr's Avatar
dust will be a major issue. Ull have to clean the components frequently.
most of the time i shutdown my PC to clean off the dust from fans and heatsinks.
And in moist climate dust + moisture cud cause serious damage for components.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 16-02-2008, 09:44 PM   #14 (permalink)
shud i remove one card or shud i continue DLing with SLI??
i frequently clean the internal components of my PC so thats not a prob.Im worried abt my GPU's
Old 16-02-2008, 09:45 PM   #15 (permalink)
Wire muncher!
infra_red_dude's Avatar
Use everest to hdtemp to check hdd temps. Best would be to use the "oldest" PC in your home and make it a headless download box. Control it via your other PC. Let it be the slowest computer amongst all you haf, strip off the floppy/optical drive/kb/mouse/monitor/pref. onborad gfx and run Linux on it.
Configure it and and disable the GUI and make it a media server and download box. Apart from being a download box, it'll also serve as your central repo for all your songs/videos and what not. Just plug in the high capacity hdds to it
Using your rig for long hours only for downloading is utter waste of cpu and gpu cycles. Not to mention the power that monster draws for doing nothing!
infra_red_dude is offline
Old 16-02-2008, 09:52 PM   #16 (permalink)
im confused.
my 1st sys is a lappy so cant Dl on it.
2nd sys -my dad will be using it for office work at home on the other room where i dont have internet.
3rd ps is my brother's.he wont give me his gaming rig for DLing.
i am left with this box only.what to do??
Old 16-02-2008, 10:08 PM   #17 (permalink)
Wire muncher!
OK you can use this system, but give it some rest after some dayz, mebbe for a few hours. The only reason why I suggested that was to save power/noise and also that while the download/media server is downloading heavily you can still play a high end game on your PC
Old 16-02-2008, 10:09 PM   #18 (permalink)
ancientrites's Avatar
heheh i switch off my pc for 1 hour(10.00pm to11.00p.m) in the night.i have huge d/ling stuff.its been one year zeb730watts still keeping its promise.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
ancientrites is online now
Old 16-02-2008, 10:13 PM   #19 (permalink)
with this config??????
Old 16-02-2008, 11:03 PM   #20 (permalink)
dOm1naTOr's Avatar
The GPUs will be idle while on normal work or dling. The GTU temps will be down to bottom and the GPU fans will be running at lowest speeds. U can manually turn down their speeds to lowest using rivatuner. But make sure they are hiked up back before starting any game.
The only thing gonna worn out are fans. Their bearings has a maximum rated lifetime of work and the lifetime cud be stretched if they are turning at lower speeds.
If ur system is gonna run foe very long time and at absolutely no loads , then i recommend u to plug off some system fans coz heat wont be issue, but dust maybe.
Or use the system in ur siggy for dls and free the burden off your 8800GTS SLI
celeron is gud at handling dls
G3: XPS M1530 |
FZ 16.
Old 17-02-2008, 12:08 AM   #21 (permalink)
i would use that config if i had it!!but HDD is only 128 MB
Old 17-02-2008, 12:30 AM   #22 (permalink)
Wire muncher!
I think it can handle till 80GB. Just plug in ur IDE hdd and see. Then use it as a download RIG Best option!
Old 17-02-2008, 12:42 AM   #23 (permalink)
lemme tell u that i dnt have that sys.my sig is a joke!!!
ill be getting my bro's system very soon coz he ll also be getting a gaming beast.Till then il have to ise this pc for DLing.
ab hamare paas koi vikalp bhi to nahi hai
Old 17-02-2008, 12:43 AM   #24 (permalink)
At Hell's Disq
hellgate's Avatar
i dont think u'll hav any probs.even i use my rig for bout 12-16hrs a day (mostly for downloading thru MO)
hellgate is offline
Old 17-02-2008, 02:06 AM   #25 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Use a blower to clean ur PC components!
Its easier to use and doesn't require to remove ur hardware!
keith_j_snyder2 is offline
Old 17-02-2008, 09:08 AM   #26 (permalink)
not a wise advice, huh.
Faun is online now
Old 17-02-2008, 09:48 AM   #27 (permalink)
sachin_kothari's Avatar
i am used to keeping my PC on for say days together.
only time i shut it off when there is a power failure, typically on thursdays.
i have never faced any problems with my system.
so be rest assured and if you are still worried follow above advice to monitor system temperatures.
sachin_kothari is offline
Some querries abt PS3 SunnyChahal Hardware Q&A 5 14-02-2008 11:09 AM
how to keep track of responses to querries rachitpant QnA (read only) 3 17-01-2008 07:47 PM
My First Set of Querries. mind_is_on_fire Hardware Q&A 4 06-09-2007 12:17 PM
Querries on set top box! mandar5 QnA (read only) 1 04-06-2006 12:27 AM
BLUETOOTH QUERRIES mandar5 Mobiles and Tablets 12 19-02-2006 11:55 PM
