Old 16-02-2008, 08:10 PM   #1 (permalink)
The High 5 Flyer
sam9s's Avatar
Default Seagate Barracuda 7200.11 500GB OR WD CaviarŪ 500GB SE16
I am about to buy an internal 500GB HDD, two options .......I want a very quick suggestions from you all...
1. Seagate Barracuda 7200.11 500gb............features perpendicular recording technology and a huge 32MB buffer....
http://www.specialtech.co.uk/spshop/...productid=5159
2. WD CaviarŪ SE16 7200 500GB................features 16MB buffer and brand name Western Digital
http://eshop.macsales.com/item/Weste...al/WD5000AAKS/
Need a quick suggestion which one to go for......I'd love to have some live examples who are currently using the HDDs........thanks in advance.....
sam9s is offline
Old 17-02-2008, 01:13 PM   #2 (permalink)
Default Re: Seagate Barracuda 7200.11 500GB OR WD CaviarŪ 500GB SE16
The Seagate Barracuda 32MB one will beat the Western Digital in almost all the categories like Burst Rate, Avg Transfer Speeds, Write Speeds, etc.
For more information you can check out this chart from Tom's Hardware:
Tom's Interactive 3.5" Hard Drive Charts
The 500GB WD model u specified is not there but you can get a idea while comparing with an older WD500GB or newer WD 750GB ones.
It beats both of them in most of the categories there.
IMHO, you should go for the Seagate Barracuda 7200.11 500GB - ST3500320AS model.
shadow2get is offline
Old 17-02-2008, 04:49 PM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
Thanks .....since no body bothered to reply I appriciate your concern. I talked to some of my other online friends and they also suggested the same. So finally I went for Seagate Barracuda 7200.11........will post some benchmarks soon.......thanks again for the reply.....
sam9s is offline
Old 18-02-2008, 02:13 PM   #4 (permalink)
Good Boy
george101's Avatar
how much is it any way???
george101 is offline
Old 18-02-2008, 03:49 PM   #5 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Normally i never says good about seagate and a diehard western Digital supporter but with 32MB Cache....seagate is a better choice if the price is same!
keith_j_snyder2 is offline
Old 19-02-2008, 03:46 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
Price diff is negligible, couple of hundereds. Got this one for 5400. Incidently external HDDs 500 GB USB 2.0 are also around the same price......
Yes I know WD has earned its name but segate for now with its perpendicular recording tech and 32 MB buffer easily beats WD caviar in all benchmarks......plus I have been using segate right from the begining when I bought my first 2.1 GB HDD (still keeping it as a souvenir) so reliability is no concern as well I guess.
sam9s is offline
Old 19-02-2008, 10:30 PM   #7 (permalink)
Rising ApocalypsE
Yup...Seagate is better, but only with 32MB L2 Cache!
Saw few benchies!
Help purchaisng the 500GB harddisk nawaz123 Hardware Q&A 24 19-01-2008 11:04 PM
Problem with Seagate Barracuda Aleena QnA (read only) 3 15-10-2004 04:43 PM
