Old 16-02-2008, 04:24 PM   #1 (permalink)
Default Problem with my PSU
My pc keeps shutting down by itself ever since I upgraded it.
I moved from a Athlon64 3000+, 512 MB RAM and ATI RS480 mobo to a X2 4000+, 2 GB RAM and AMD 690G mobo. The rest of the pc is the same: X1600Pro graphics, 2 DVD writers, 2 HDD's and a generic 400W PSU.
Sometimes it works for days without a hitch (even under load) and sometimes it shuts down within minutes of booting.
I constantly have to readjust the PSU cable pushing it tightly into it's socket since even the slightest movement turns it off. I have tried using another cable but it didn't help.
Is 400W not enough and I need a higher rated PSU or is 400W enough and I only need a replacement for the same?
drvarunmehta is offline
Old 16-02-2008, 04:32 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Problem with my PSU
a 400W PSU is enough for this but not the cheap one.u need a Zebronics\VIP\Coolermaster PSU
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 16-02-2008, 04:34 PM   #3 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
400 W is fine but i strongly suggest to have atleast 500W (if a local one) or 400W ( if using a branded one)!
Seems that the problem is with socket.
Try to use some another PSU if possible otherwise buya POWERSAFE 500W Silver or Gold.
keith_j_snyder2 is offline
Old 16-02-2008, 04:46 PM   #4 (permalink)
The one I have is a VIP. I consider VIP and Zebronics "generic".
How much will a Powersafe 500W gold or silver cost?
Old 16-02-2008, 10:52 PM   #5 (permalink)
Rising ApocalypsE
Somwhat between 1500-2000/-....but its better than Zebronics!
Old 16-02-2008, 11:31 PM   #6 (permalink)
I'm considering buying this PSU. Is this overkill or worth it?
Cooler Master eXtreme Power 500W
Specs:
+3.3V:20A
+5V:20A
+12V1:16A
+12V2:16A
-12V:0.8A
+5VSB:2.0A
20/24Pin ATX12v
Rs.3,200/-
Old 17-02-2008, 12:09 AM   #7 (permalink)
Multicore Mutant
If budget is no prob. then go ahead, they are very reliable.
Hackattack is offline
Old 17-02-2008, 12:14 AM   #8 (permalink)
Ethan_Hunt's Avatar
Specs:
+3.3V:20A
+5V:20A
+12V1:16A
+12V2:16A
-12V:0.8A
+5VSB:2.0A
20/24Pin ATX12v
Rs.3,200/-
Unless you are planning to go in for a graphic card upgrade later on I would say stick to the Powersafe 500W Gold SMPS for now.I have the same & takes care of all the needs without a hitch.
V for Vendetta
Ethan_Hunt is offline
Old 17-02-2008, 12:53 AM   #9 (permalink)
dOm1naTOr's Avatar
very correct
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 17-02-2008, 01:51 AM   #10 (permalink)
Rising ApocalypsE
Specs:
+3.3V:20A
+5V:20A
+12V1:16A
+12V2:16A
-12V:0.8A
+5VSB:2.0A
20/24Pin ATX12v
Rs.3,200/-
Dude it has a dual 12V rail! and u can easily hook it to a SLI system too!
Otherwise POWERSAFE is the best among the low-mid PSU's!
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
