Old 16-02-2008, 12:31 PM   #1 (permalink)
Default Lite on DVD RW
I've bought a Lite On DVDrw (DH-20A4P07).WinXP recogonizes it as an atapi dvdrw & installed a digitally unsigned driver.In Nero the drive is showing only 4x speed for dvds but doing well for cds.It is rated 20x for dvds and 48 for cds.Pls help me.
j4jubin is offline
Old 16-02-2008, 12:41 PM   #2 (permalink)
sachin_kothari's Avatar
Default Re: Lite on DVD RW
check what speed does the dvd supports.
the dvd rom supports 20x, may be the dvd supports max 4x.
sachin_kothari is offline
Old 16-02-2008, 08:15 PM   #3 (permalink)
pushkaraj's Avatar
Smile Re: Lite on DVD RW
That is because the dvd that you are using supports upto 4x write speed. Try a dvd of another brand that has support for 8x or more and see if still nero shows the write speed as 4x.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Flash Lite 3 For N95 8gb mohitgiri Mobiles and Tablets 5 24-01-2008 02:30 AM
Lite-on DVD recorder geraardo QnA (read only) 1 09-12-2007 09:36 AM
Ace or K-lite vish786 Software Q&A 20 18-04-2007 02:27 PM
Kazaa Lite K++ ! ! ! ax3 QnA (read only) 2 24-06-2006 01:36 AM
Lite-On DVD Writer Sam Fisher QnA (read only) 2 09-05-2006 02:27 PM
