Old 16-02-2008, 12:21 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Wireless Keyboard Mouse Problem?
Hi Guys!
I just brought a Logitech Combo of Wireless Keyboard Mouse and installed the same. The problem is that even if I switch off the Computer, the lazer in the mouse is on. This means that the mouse is always active and the same must be happening with the Keyboard also. Now, this would drain off the batteries very soon. Is there a way to switch off the Mouse and Keyboard when not in use.
Please dont say to take off the batteries as this would be the dumbest idea. BTW, how long will my battery last if my computer is on all 24 hrs.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 16-02-2008, 01:27 PM   #2 (permalink)
slugger's Avatar
Default Re: Wireless Keyboard Mouse Problem?
wirelss keyboard+mouse cannot b turned off (other than the method u dismissed ))
when not in use their power consumption drops down drastically
BTW wat kinda batteries u go in there?
slugger is offline
Old 16-02-2008, 01:51 PM   #3 (permalink)
9437077259
go4saket's Avatar
Its an AA(Pencil) Cell... As of now, I am using Duracell that came with the package. Will shift to rechargeable later...
Win 7 Ultimate
go4saket is offline
Old 16-02-2008, 03:11 PM   #4 (permalink)
slugger's Avatar
if u usin the Mn-dioxide batteries, then u wint have to bother takin them out
it wud get discharged evn without use
slugger is offline
Old 16-02-2008, 05:15 PM   #5 (permalink)
dattebayo
anispace's Avatar
d keyboard hardly consumes any power when not in use so u only have to remove the mouse batteries. There isnt any other option imo.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Wireless Keyboard+mouse naveen_reloaded Peripherals 8 08-12-2008 09:40 PM
Help! Purchasing Wireless Keyboard+Mouse BittooTheBe(A)sT Hardware Q&A 5 15-01-2008 09:45 PM
How much a Wireless keyboard + mouse cost? hafees QnA (read only) 10 19-08-2007 12:36 PM
