Old 16-02-2008, 11:40 AM   #1 (permalink)
The pWnster
Vyasram's Avatar
Default UPS with best voltage regulation
I want a UPS which has the best voltage regulation features . My area is worst affected in the summer where voltages drop tremendously. Will a UPS do the job or should I look for a stabilizer?
PC conf- AMD 3000+,1GB RAM, 2 HDDS, 2 Optical Drives, 6600GT
average backup would do ( 10 mins or so).
Sigs suck
Vyasram is offline
Old 16-02-2008, 11:49 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: UPS with best voltage regulation
wats the voltage when @ max voltage drop.if its below 185v then APC is out of the question.
if below 165V then ruleout powercom and think bout getting Microtek though i wont be able to tell u if the Microtek will work below 165V but the Powercom works for anything above 165v that i can tell 4 sure as i hav 1.
hellgate is offline
Old 16-02-2008, 12:41 PM   #3 (permalink)
The pWnster
Vyasram's Avatar
i dont know the max drop
But Microtek 800VA double battery UPS doesn't work at that voltage( it goes into backup mode, after every voltage drop)
but, my Wipro 500VA emerge handles it fairly well . Is there anything better than Wipro when it comes to AVR
Sigs suck
Vyasram is offline
Old 16-02-2008, 04:59 PM   #4 (permalink)
APC SmartUPS is what you should be looking at. They cost double of what the normal ones cost though! I have a 1500VA one that costed me roughly 18 grand. Never seen it go to battery backup mode because of voltage drops/spikes. It has an inbuilt AVR.
http://www.apcc.com/products/family/index.cfm?id=165
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 20-02-2008, 03:01 PM   #5 (permalink)
Norms Buster
Buy this :
http://www.vguard.in/product_details...Id=89&proId=82
VexByte is offline
Over voltage bug uday56 Software Q&A 9 13-01-2008 03:08 AM
Voltage problem.. medigit Hardware Q&A 2 27-04-2007 11:35 AM
SMPS Voltage low midhunmon Hardware Q&A 3 23-08-2006 02:09 PM
CPU Over voltage geek007 Hardware Q&A 4 25-11-2005 03:08 PM
