Old 15-02-2008, 11:58 PM   #1 (permalink)
Arun the Gr8's Avatar
Angry dvd writer read problem... help!
frm few days ny sony dvd writer has become very slow in reading dvds. i just dont understand wht happened. when i play any song while copying from a dvd... the song runs very slow. also the data too gets copied at a very slow rate. can u guyz help?
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 16-02-2008, 12:03 AM   #2 (permalink)
::cyborg::'s Avatar
Default Re: dvd writer read problem... help!
is ur model dru 820 somehing like that then it is normal bcoz these models did hav problems
:)) - KEEP SMILING
::cyborg:: is offline
Old 16-02-2008, 12:18 AM   #3 (permalink)
Unhappy Re: dvd writer read problem... help!
actually it is an oem edition.... dw-q28a... n it worked quite well til now..
Old 16-02-2008, 09:50 AM   #4 (permalink)
Check whether dma is disabled...
Let there be music.....
sashijoseph is offline
Old 16-02-2008, 11:19 PM   #5 (permalink)
Question Re: dvd writer read problem... help!
how do i do it in win xp...
also.. burning process failed in 2 of my dvds... both sony while writing in 16x... though one dvd i burnt in 8x... and d data was verified successfully in it... wht do u think is d problm??
Old 16-02-2008, 11:23 PM   #6 (permalink)
Multicore Mutant
Check the dma as said above.
Or you may run this vbs script.
Hackattack is offline
Old 18-02-2008, 03:35 PM   #7 (permalink)
Boy Waiting To Be A Man!!
kayos's Avatar
before using the vbs goto device manager and check for the primary and secondary rives in ATAPI controllers...
check in teh advanced setting if transfer mode in PIO or DMA..
if its PIO then make it DMA and restart ,..
check again .. it might have rechanged to PIO .. if it isnt then good otherwise run that vbs ..
if it still doesnt help then there is a tutorial in tutorial section ...
look for that ..
hope it helps !!!
With No Power Comes No Responsibility !!!
-Clark I
kayos is offline
Old 18-02-2008, 03:42 PM   #8 (permalink)
slugger's Avatar
if u have eliminated the UDMA issue and problem stil exits then check out this thread
http://thinkdigit.com/forum/showthread.php?t=80393
also 16x being the maximum ur writer can write at, better not to burn it at that speed. chances of failure increases manifold
8x is fine, tho 4x if feel is even better 4 ur writer [shud take around 15 mins 2 burn 4.5 GB]
slugger is offline
LG DVD Writer Cant read Cds but Reads All DVDS... hmmmmmmmmmmmmm QnA (read only) 4 07-10-2007 08:12 AM
DVD writer wont read cd's a_tif Hardware Q&A 20 14-08-2007 08:17 PM
DVD writer doesn't read CDs well adithyagenius Hardware Q&A 7 08-06-2007 06:39 PM
DVD Writer Read Problem in XP klerajay Hardware Q&A 2 21-04-2007 10:00 AM
combo drive problem read some dvd dosen't read others q4_abhi Hardware Q&A 4 03-04-2007 05:09 PM
