Old 14-02-2008, 11:08 PM   #1 (permalink)
p@rkour
zebanon's Avatar
Question My screen blinks...........
Hi frnds , need ur help..my screen blinks after i close all da connections ( UPS n main switch)...my screen is LG FLATRON (model no: L 1752S). I hav tried 2 solve it but cant..when i read its guide, it was given dat " CHECK IF DA SCREEN IS SET 2 INTERLACE MODE ,IF YES CHANGE IT 2 RECOMMEND RESOLUTION"..can anyone say wat does it mean n how 2 do it?????.....
Keep Thinking Hard , anytime u can be wid a great IDEA!!!!!!!!!......:)
This is my new blog in which i m sharing my ideas n thoughts in engineering life..
http://enggstudent-zebanon.blogspot.com/
zebanon is offline
Old 15-02-2008, 04:15 PM   #2 (permalink)
Norms Buster
Default Re: My screen blinks...........
The monitor may be nearing it's life(cathode tube).
VexByte is offline
Old 17-02-2008, 01:13 PM   #3 (permalink)
p@rkour
zebanon's Avatar
Thnks 4 reply...but 4 ur info i hav bought it 5 months ago .....i asked u this "CHECK IF DA SCREEN IS SET 2 INTERLACE MODE ,IF YES CHANGE IT 2 RECOMMEND RESOLUTION"....do u know wat does it mean??
zebanon is offline
My screen blinks... zebanon Software Q&A 1 11-02-2008 10:26 PM
monitor led blinks,bt not working.pls help mobileman Hardware Q&A 16 01-11-2006 04:28 PM
PC does not starts....beeps+blinks navjotjsingh Hardware Q&A 3 17-07-2006 02:10 PM
PC Shut-Down of it's own...Green Light Blinks!!! reddick QnA (read only) 13 13-11-2005 10:59 PM
System Blanks and Monitor Blinks while playing games Vyasram Networking 6 18-09-2005 07:40 AM
