Old 11-02-2008, 10:52 AM   #1 (permalink)
Default Motherboard for Athlon XP
I have a system based on Athlon XP 1800+. My motherboard is gone and cannot be repaired. Is there any other motherboard available in the market for this cpu?? Like Asus A7N8X or something like that??
parimal is offline
Old 11-02-2008, 10:55 AM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: Motherboard for Athlon XP
There are no motherboards available for Athlon XP processors. You can get some 2nd hand motherboards if you look for them
http://twitter.com/akshayms
nvidia is offline
Old 11-02-2008, 11:02 AM   #3 (permalink)
j1n M@tt's Avatar
u hav got a 939 socket processor.....u hav to get mobo based on this socket, and its a difficult task b'coz its outta production.
So u better get an AM2 socket based processor and mobo. And its easy on budget than going of the above solution.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 11-02-2008, 11:38 AM   #4 (permalink)
Where I can get second hand motherboards in Mumbai?? Any specific shop??
parimal is offline
Old 11-02-2008, 06:08 PM   #5 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
athlon XP .. is way old man. its not 939
Athlon64 has two sockets 754 & 939, Athlon64 X2 has AM2 Socket
AthlonXP must be having some earlier socket I think its Socket A.. like my oldie K6-2 processor.
@parimal
Although I would also suggest that just buy a new MB n Processor ..
it will cheaper comparatively.bcoz they charge u anything if you did get one.
X2 4000+ & MB = Rs. 5.5k! and be free for few more years
rollcage is offline
Old 11-02-2008, 07:02 PM   #6 (permalink)
and wat abt new ram ? if he has more than one hdd.. .these mobo's offer only 2 IDE . . .but performance wise , its worth it.
sagargv is offline
Old 12-02-2008, 02:02 AM   #7 (permalink)
rollcage's Avatar
ya but getting board at 3k for that nouse, or if he gets secondhand .. it cant be said how long it gonna last!
rollcage is offline
Old 12-02-2008, 09:24 AM   #8 (permalink)
^^ agreeable . but the OP has to have the budget for it.
sagargv is offline
Old 13-02-2008, 12:32 PM   #9 (permalink)
Yeah...good suggestion. But I want to run my PC only for 2-3 months. After that I'm planning for Penryn. Also now I don't want to spend money on DDR2.
parimal is offline
Athlon X2 Or C2d? neel12345 Hardware Q&A 4 22-10-2007 09:25 PM
Price of AMD Athlon 64 FX with motherboard lalpac CPU / Motherboards 1 18-02-2005 05:55 PM
Want a Motherboard+Athlon 64 FX+Video Card+256 RAM ** 16000/ dspawar CPU / Motherboards 14 17-11-2004 11:21 PM
