11-02-2008, 08:32 AM
Tough decision.Laptop buying.
I posted the same question on the Q&A forum ,but was not able to get much feedback on my question. I want to buy a laptop in the range of 35k.My primary use is for official work, but I am also an avid gamer. Please suggest some models which can play Doom 3/Half Life 2 etc.
I have checked the sites of HP,Dell & Acer, but could not come to a conclusion. How are Acer laptops by the way?
I am really counting on all you guys.Thanks.
11-02-2008, 09:48 AM
Re: Tough decision.Laptop buying.
Please suggest a one which comes with a graphics card so that I can play the games.Somebody please help.
11-02-2008, 10:13 AM
If u want a gaming laptop then the best choice for you would be a dell laptop with 8600gt card. Its the most value for money gaming laptop.
11-02-2008, 10:14 AM
TechTin.com
I will suggest you to invest few bucks more and get DELL 1525. In 35K , I will suggest compaq V6608.
11-02-2008, 10:39 AM
^^ +1
I too suggest Dell...........configure it online to suite the budget range.
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
11-02-2008, 05:50 PM
Compaq V6608 has been discontinued. Can you please suggest some more options of Compaq/Acer with the needs which I have mentioned. I am checking out Dell.
11-02-2008, 08:19 PM
Hey guys! I am really counting on all of you to arrive at a decision.
11-02-2008, 08:21 PM
At Hell's Disq
^^^ V3702AU has replaced V6608AU.both hav almost same specs.
11-02-2008, 08:47 PM
Dell with 8400GS or 8600GT cards, based on your budget.
12-02-2008, 07:50 PM
V 3702 AU is AMD based while 3702 TU is Intel based; will there be any issues with the AMD processor later, since I had one in my dektop & it used to get extremely hot.However, the AMD based lap comes with a Nvidia graphics card while the intel comes only with onboard graphics. Can I play Doom 3/Half life 2 smoothly on the Intel one or the AMD ?
Please help.
12-02-2008, 07:52 PM
Google Bot
Nah man. No overheating issues on the turions. and 7150m > x3100
12-02-2008, 11:13 PM
At Hell's Disq
^^^ but 7150m doesnt hav dx10 support whihc the x3100 will hav once dx10 drivers r released by Intel in march.
13-02-2008, 07:15 AM
Hey guys! don't you think that things are getting a bit confused? So what will it be? As far as I know dx 10 is needed for the latest games. So the AMD chipset will not be able to handle the games? Please suggest!
Or shall I settle for the Dell laptop?
Please help!
13-02-2008, 11:56 AM
At Hell's Disq
none of the lappies mentioned above r meant 4 gaming.they can run a few games at low to medium setting but gaming on them is not recommended.
i wud suggest u to get a Intel Dual Core T2330 + x3100 combo any day.
T2330 is stripped down with C2D with only 1MB L2 and 533MHz fsb.
T2330 + x3100 performs better than C2D T5250 + x3100.
so just close ur eyes and get any Compaq/HP lappy based on T2330 + x3100.
14-02-2008, 10:53 AM
Can you please elaborate this, do you have any technical links? I would like to learn more
Reason: Automerged Doublepost
14-02-2008, 12:02 PM
I always thought c2d was better than dual core. its first time that someone has mentioned that dual cor is >> c2d.
14-02-2008, 12:38 PM
So what's it going to be? Shall I go for the Compaq V3702 AU or something else? Please help.
14-02-2008, 01:57 PM
1. no point of going for a directx 10 compatible IGP (ie x3100) as anyway u wont be able to play the latest game with the onboard videocard.
Even if u r able to play in low very low setting u wont find much difference for directx 9 vs 10
2. Directx 10 would require u to install vista which i thing is not as good as xp (personal opinion)
3. for gaming 7150 is better than x3100 (read it on some forum will post the link soon)
So go for Compaq V3702 AU or compaq 6608au (+15.4 " screen, -no webcam) if u can find it with 2 gb ram
14-02-2008, 06:37 PM
#19 (permalink)
O.K.Just tell me, that can I play Half Life 2/Doom 3 on this Compaq 3702 AU.
14-02-2008, 08:21 PM
#21 (permalink)
Google Bot
Yup you can. 7150m is the best IGP currently.
BTW a t5250 > a t2330.
15-02-2008, 12:09 AM
#22 (permalink)
At Hell's Disq
i've attached the Everest Report for both T2330 (Compaq C739TU) and T5250 (Compaq C713TU).
see the difference for urself.
15-02-2008, 08:16 AM
#23 (permalink)
Compaq 6608 AU has been discontinued; any other model based on t5250?
15-02-2008, 10:10 AM
#24 (permalink)
models based on t5250 -- acer 4720
Dell inspiron series 1420, 1520, 1525
16-02-2008, 06:13 PM
#25 (permalink)
At Hell's Disq
so guys hav u seen the Benches for both the T2330 & T5250.
so wat do u hav to tell??
16-02-2008, 08:28 PM
#26 (permalink)
O.K .I have got the Compaq 3702 AU today.It's pretty cool, & I simply am in love with it. Thank you all very much, for the continous help which you have given to make me the best choice. Thanks to all of you once again.
16-02-2008, 10:21 PM
#27 (permalink)
At Hell's Disq
^^^ cud u plz give me the rating for the Windows Experience Index for ur laptop.
i want the full ratings for:
Processor
ram
gfx
and hdd.
16-02-2008, 11:54 PM
#28 (permalink)
@harpoon how much did u buy ur laptop for? could u give a review of ur laptop
17-02-2008, 11:16 AM
#29 (permalink)
The price which I paid is Rs.32,500/- inclusive of all taxes. Please give me a few days time to give a full review.
17-02-2008, 07:20 PM
#30 (permalink)
Google Bot
Where did u get it from? what accessories? more details..
