please use search
as this is what I can find
-------------------------------Quote-----------------------------
How can we know the password? The original assembler who assembled the PC may not be available.
not possible to recover the BIOS PW
Can anyone of you help me on the above?
One think which can be done is to reset the BIOS... there are 2 ways, via jumper or via bettery reset..
Jumper Settings
Locate this jumper as show in the bellow image !!!
there are 3 pins, like
* * * the pin would cover 1 and 2 pin which is the default config...
- - * so take the pin out and put it as 2 and 3 cover like,
* - - start the system
the BIOS should revart back to the default shipping factory settings... !!! now power of the system and restore the jumper to default 1 and 2 cover settings
start the system once again to do you work
next option removing the battery
locate the bettery as show in the picture
remove it and then wait for 5 pins, plug it back to start the system
it would be restored to the factory settings
here :-
bios password of Intel motherboard D945GCCR
