I need to Upgrade to 160 HDD and 1 GB ram .....Just want to will my motherboard support????????. And if in case i installed Ram of different
speeds like (256 mb (266 mhz) and 1 gb (433 mhz) ) will it affect my system
Plzzz suggest me what i can do
SR
the 160GB hdd wont cause any probs.
for the ram,sell ur present 256MB stick and get 2*512MB if u dont plan to add any more ram lateron else get a 1GB stick.
b4 buying the ram just see the max ram speed supported by ur mobo.
