Old 10-02-2008, 07:47 AM   #1 (permalink)
Default my system is dead slow being the latest hardwares
my system configuration is
intel core 2 duo 2.2 ghz
intel 945 gcnl mother board
dyanite 1 gb ddr2
seagate 160gb sata
samsung dvd writer
bought before two weeks before am having pentium three which has 256 mb sdram and 810et msi mother board this configuration is faster than the above . system gets busy often even my p3 system didnt get busy with that 256mb ram but what this contains core 2 duo processor and 1gb ram often gets busy and not responding and cant even play games says you must have 3d accelerator
any one help me to solve this problem please
prakashr85 is offline
Old 10-02-2008, 07:51 AM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: my system is dead slow being the latest hardwares
Are you running Windows?
XP or Vista?
Have you installed all the drivers provided by the vendor?
Any antivirus?
Any file indexing service?
Any defrag service like diskeeper?
Do you use Limewire, Ares, torrents, or other forms of P2P?
From the looks of this page here, you might have to install a separate 3D accelerator.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 10-02-2008, 08:04 AM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
what about PSU?
btw check for loose cables (usually HDD's) & reseat the RAM.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 11-02-2008, 02:52 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Overheating might also be an issue.Check your BIOS for Hardware Temperatures
techtronic is offline
Old 11-02-2008, 08:45 AM   #5 (permalink)
dOm1naTOr's Avatar
i doubt it cud be some HDD issue. Such sluggishness happens if there is a chance of bad sectors nd efven new hdd cud develop bad sectors.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 11-02-2008, 08:47 AM   #6 (permalink)
left this forum longback
praka123's Avatar
@OP:install seatools for windows and check for sure that ur hdd is stable or not.if it fails short test ,time to go for replacement
praka123 is offline
Old 11-02-2008, 11:13 AM   #7 (permalink)
Unmountable Boot Volume
Cyrus_the_virus's Avatar
Solution: Uninstall Vista and Install Ubuntu 7.10. You're computer will fly with those configs!
PS: Please don't start an OS flame war here!! I just gave my opinion, if anyone likes it, take it, else chuck it!
Webhosting for Rs12/month!!
http://www.thinkdigit.com/forum/showthread.php?t=74717
http://www.outpowerhosting.com
Cyrus_the_virus is offline
Old 11-02-2008, 11:39 AM   #8 (permalink)
hehe I should have +1 but he wants to play games
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is online now
Old 11-02-2008, 02:37 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
Looks like some hardware issue.
1) Make sure all hardwares are compatible with each other.
2) All drivers are installed.
3) Perform chk hard disk.
All, see how much memory, and processor is being used, and what program are using it.
he has not mentioned that he is using vista.
ravi_9793 is offline
Old 11-02-2008, 05:41 PM   #10 (permalink)
Boy Waiting To Be A Man!!
kayos's Avatar
i think he missed a driver....
everythings compatible as system is working ...
just chekc if all hardware is being recognised by system manager..
also ur drivers are properly installed ..
then do tell here whats the status of ur CPU ..
which program is running and if any program is taking more then necessary memory..
With No Power Comes No Responsibility !!!
-Clark I
kayos is offline
Old 11-02-2008, 05:53 PM   #11 (permalink)
damn busy...
utsav's Avatar
He may not hav installed the display driver and all the gfx tasks r now being handled by the cpu which is making his system sluggish
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 11-02-2008, 06:19 PM   #12 (permalink)
TheSaint
No reply from original poster
Old 11-02-2008, 06:45 PM   #13 (permalink)
arun77574's Avatar
First and foremost thing, Your PSU (SMPS) rating should be atleast 500w to be on a safer side. (My suggestion)
Install a gfx card if its asking for a 3D accelerator. The 945 chipset does not support all new games or any new games for that matter.
Do not keep too much startup items. Disable unnecessary items from MSConfig.
Dont use any antivirus which takes more than 40-50mb in ur RAM. Go for Kaspersky. (My suggestion)
Check the length of the SATA power cable. If it is long ur system will be slow. However, i dont know what exactly the length should be but, my frnd had a similar problem and everything was fine when he changed the SATA power cable. Got this piece of info from a comp service guy also a frnd of mine.
arun77574 is offline
Old 11-02-2008, 07:44 PM   #14 (permalink)
dOm1naTOr's Avatar
but even with all these reasons, i wonder how he felt the C2D system slower than his old 256 P3!!
G3: XPS M1530 |
FZ 16.
Old 13-02-2008, 08:26 PM   #15 (permalink)
using win xp sp2 no file indexing no p2p all drivers provided r installed
xp sp2 no p2p no file indexing no disk keeper using kaspersky antivirus all drivers are installed
System has become too slow Sridhar_Rao Software Q&A 7 17-09-2007 08:23 AM
System slow down bhutbhut Software Q&A 5 09-05-2007 04:54 PM
My system is very slow ranjodh Hardware Q&A 9 01-09-2006 01:55 AM
Help! My system is too slow udhaybhavan QnA (read only) 9 15-09-2005 05:44 PM
system slow pradeep QnA (read only) 9 01-06-2005 04:20 PM
