Old 08-02-2008, 04:30 PM   #1 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile Guide me in buying a new Branded desktop Pc
Hi
My brother needs a Branded desktop PC branded coz he will get it financed from his company .His bugged is abt Rs 30,000/- (excluding speaker system)
His main requirement are :
1. 17 inch LCD Moniter .
2. Tv tunner Card
3. Intel C2d
4. DVD writer
5. Graphics Card ( not must )
6. Ups
plz suggest me the best Branded PC that he can get in this price Tag
saurabh kakkar is offline
Old 08-02-2008, 05:29 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Guide me in buying a new Branded desktop Pc
i would suggest that you go and get a low end Dell or Acer desktop(meaning one with an intel C2D 5xxx processor, onboard graphics, 1 gig ram, etc) then add some extra ram to it along with an 8600GT.
Graphics cards are some of the products most cheated on by the manufacturer, and every mobo worth its salt has a PCIe slot to insert a graphics card in it.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 08-02-2008, 05:47 PM   #3 (permalink)
Boy Waiting To Be A Man!!
kayos's Avatar
pls be a bit more specific as to how you want to use ur pc ..
i hope u know that branded will not be the best deal u will get ...
and also if u at all need graphics card...
for 30k having lcd with graphics card can be a little strain ..
do wxplain a bit and i m sure u will get the best of suggestions from here..
With No Power Comes No Responsibility !!!
-Clark I
kayos is offline
Old 08-02-2008, 07:46 PM   #4 (permalink)
Question Re: Guide me in buying a new Branded desktop Pc
@MetalheadGautham: Do u think company like dell,acer cheat there customers .How can i be sure that i m getting the right parts ? R there any software to test ?
@kayos :
My brother wants to use it for his home entertainment purpose like for watching movies, playing some low end games , watching Tv etc
Yes i know dude but the thing is he will get the system financed
i want to know whether Graphic Card r basically meant for High end games and softwares ? Does a PC meant for normal use need them ? Is it required for running Vista in its full effects ?
Old 08-02-2008, 08:02 PM   #5 (permalink)
I M A *STAR*
saqib_khan's Avatar
Hi saurabh kakkar,
A pc for normal use did'nt need graphics card.
Normal use means office work, listening music, watching DVD, casual gaming.
Even i run latest games(World in Conflict) without any graphics card.
So, if u do not want it for gaming then u can give gpu a miss.
A normal PC having good chipset also runs vista in its full glory.
I have nvidia geforce 7025 chipset. So, if u want to run vista ask ur dealer to say u which chipset is that branded PC is having.
SO, only buying a normal PC with good chipset is all u need (i think so).
Blogging at:
Technostarry
saqib_khan is offline
Old 08-02-2008, 08:53 PM   #6 (permalink)
^^ if u're very mild gamer , its ok. .but for gamers who play for a few hours on weekends only also need a dedicated gpu .. paying 4-5k extra for a gpu is worth it even if u're a casual gamer.
sagargv is offline
Old 09-02-2008, 06:16 AM   #7 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
^ true and its getting way cheaper now.
but the same point in case getting a graphics card put the budget out of the limit. then which motherboard you suggest?
rollcage is offline
Old 09-02-2008, 12:29 PM   #8 (permalink)
@khansaqib101 : Thanks for clearing My doubt We have decided that we will not buy Graphic card and we can extended our range to 35k.
Now our current requirement r :
Range :30k to 35k
2. Tv tunner Card
3. Intel C2d
4. DVD writer
5. Ups
plz Suggest good Branded PC for the above requirements
Old 09-02-2008, 12:36 PM   #9 (permalink)
Rebooting
Choto Cheeta's Avatar
may i know why desktop ??? as Compaq V6608AU with 2 GB comes at Rs. 35k incl tax
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-02-2008, 10:39 PM   #10 (permalink)
Smile Re: Guide me in buying a new Branded desktop Pc
Finally a reply from our expert ( just joking ) thanks for the input saurav
Actually my brother wants the Pc for his home which can be used by him nd his small kids
and regarding Laptop he will soon be getting a laptop by his company
saurav also suggest me best assembled Pc in this range concidering above requirements I will be very thankfull to u
Regards
Saurabh kakkar
Old 09-02-2008, 11:15 PM   #11 (permalink)
Rebooting
well u are thinking the wrong way
I mean, think what you need to do with the Computer ?? What applications u plan to run, what is the purpose of the System ??
Gaming ??
Movies ??
Home Entertainment ??
Programing ??
What is your requirement ??
as judging by this comment,
No TFT TFTs are quite dalicate darling so KIDs + TFT = Problem, TFTs needs a lot of attention, and KIDs are not some thing u want to have near the TFT...
we have a dedicated thread running.....
Basic Guide Purchase a New System
may be that can give some idea
Few basics, which u should keep in mind...
KIDs mean a lot of software issue will come as they will click here and there ending up with a broken (software) system... which will need software attention... So if you and your brother can handle the software issue, then Assemble is better choice as it would offer 3 years of warrenty on Core Parts where as Branded may come with 1 year
rebooting
ChotoCheeta.com
Old 10-02-2008, 09:53 AM   #12 (permalink)
Gaming ??
only simple games like road rash and flash games
Movies ??
Yes main need we will be connecting his Sony 2.1 3000pmpo speaker system
Yes Tv tuner Card required
Programing ??
No
What is our main Hardware requirement ??
2. Tv tunner Card
3. Intel C2d
4. DVD writer
5. Ups [/QUOTE]
thanks for ^^ advice
I think now U can guide me better
Old 10-02-2008, 11:37 AM   #13 (permalink)
Rebooting
and ?? sticking to branded or Assemble ??
if branded Lenevo would be a good option http://www-604.ibm.com/webapp/wcs/st...riesid=8666535 look for Three year parts and labour choose system which are under Rs. 24k or such as u still have to replace the Optical drive with DVD RW add some ram and get a display and TV Tuner for branded, u ur self have to chat with the people at ur nearest show room so see who is offering better value for money
rebooting
ChotoCheeta.com
Old 10-02-2008, 04:03 PM   #14 (permalink)
Actually i m confused 80% we will be going for the assembled
^^ Thanks for the this valuable info Can u tell this Lenevo machine that u have Quoted will be able to support windows vista without a hitch
plz tell me the assembled counterpart in the above mentioned range and requirements that i have mentioned also suggest me which compnany Tv tuner Card to buy
regards
Saurabh kakkar
Buying PC - Branded or Assembled? wealthyminds QnA (read only) 14 06-11-2007 06:13 PM
Suggest a good Branded desktop PC gurujee Hardware Q&A 13 26-08-2007 10:07 AM
Suggest a good Branded desktop PC gurujee QnA (read only) 2 26-08-2007 12:17 AM
Decision for buying branded p.c.Advise needed. harpoon Hardware Q&A 5 02-05-2007 02:30 PM
PS2 buying guide satyanjoy Gamerz 1 10-04-2007 03:53 PM
