Re: Want to make my house WiFi!
My experience with wireless at home hasn't been too good. I used a Netgear WAP, and found out that it was giving me access only in that room and the next. I believe that
1. The signals don't bend round corners very easily (like sound waves do)
2. They don't penetrate walls (not too sure about this, I was told so)
3. Signal is broadcast as a "Sphere of influence" from the antenna, by changing the direction of the antenna, you can shift this "sphere"
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
