I want to buy a hdd. I want to install *leopard* on it Which hdd should i opt for ?? sata-2 or ide (7200rpm)?? Which will give better performance and zero problems on installing leopard...
By Regards,
Amey.
as of now i havent tried installing Leopard on my pc but hav installed OS X and i wanna tell u that OS X will install perfectly on IDE hdd but wont boot from it.
u need a sata hdd for installing and running OS X.
^^^ if u wanna install in a pata hdd then u'll hafta install thru VMWare though u may not get audio and lan support.
