Old 08-02-2008, 08:09 AM   #1 (permalink)
Thumbs down Azeureus Port Errors.....
i have been trying a lot of things till today to unlock the connection port of it. please help me to do so. i am using DataOne Broadband and my modem is UT Starcom UT300R2U.
Edit:i have tried disabling XP's firewall but no avail.
upendra_gp is offline
Old 08-02-2008, 08:55 AM   #2 (permalink)
The Unknown's Avatar
Default Re: Azeureus Port Errors.....
first, this is a wrong section.
second, you have to add the port no. to the firewall-port-allow list.
KDE on ArchLinux
The Unknown is offline
Old 08-02-2008, 09:01 AM   #3 (permalink)
sorry for wrong section. yes i added TCP. shud i add UDP also?
Old 08-02-2008, 09:59 AM   #4 (permalink)
yes UDP also
KDE on ArchLinux
Old 09-02-2008, 11:11 AM   #5 (permalink)
moshel's Avatar
ok for that you will have to enter into ur modem settings from internet explorer..it might be something like http://192.168.1.1 ...and somewhere over there you will find settings to open up ports.
thats how i did on my BSNL adsl connection.
moshel is offline
Old 09-02-2008, 12:02 PM   #6 (permalink)
Pee into the Wind...
shady_inc's Avatar
An easier solution is to just enable UPnP [Universal Plug n Play] in your router and set Azurues to use UPnP.Do this only if you know your Router supports UPnP.Click me.
Life is as complicated as you say it is.
shady_inc is offline
Old 10-02-2008, 10:37 PM   #7 (permalink)
moshel can u please tell me how to do that?
Please sort out these Errors Pragadheesh QnA (read only) 7 14-08-2006 11:49 PM
Broadband Modem: One USB port to Two USB port ajinkyakulkarni87 Hardware Q&A 3 03-08-2006 09:56 AM
ICS and DNS errors gorky QnA (read only) 1 13-11-2005 12:16 AM
Explorer.exe errors foreveranuj Software Q&A 2 17-01-2005 02:08 PM
CRC Errors!!! BLITZ~KRIEG! QnA (read only) 5 04-11-2004 05:29 PM
