Old 07-02-2008, 04:31 PM   #1 (permalink)
Red face Problem installing new hard disk
hi, friends my system config is:
Intel EM64T 3 ghz processor, Asrock 945gl dual motherboard having 6 sata ports, 1 gb ddr ram, 80 GB, i am running windows XP.
My problem is, recently i have bought a 160 GB sata seagate hard disk but my sysmtem is not reporting that hard disk. I have tried every possible way to connect it but of no use.
Now when i connect that same hard disk to my friends system( quadra core 2.4 ghz, Gigabyte 946 s sreies mb, 3 gb ram) it is getting detected without any problem... can you plz help me out.
thanks in advance..
nanop1i is offline
Old 08-02-2008, 03:13 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: Problem installing new hard disk
Check whether RAID is enabled in your Motherboard BIOS.
If yes disable it and then try connecting our Hard Drive
techtronic is offline
Old 08-02-2008, 08:55 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
Did ur mobo bios detected the new HDD.
Have enabled all sata ports in bios.
Do check those & reply.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 09-02-2008, 12:47 AM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Check in ur BIOS whether that new HDD is being detected or not.
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Installing from hard disk ThinkFree Software Q&A 1 23-04-2007 05:41 PM
Hard Disk Problem. Plz Help iwant2breakfree Hardware Q&A 9 18-01-2006 07:59 PM
installing dos 6.0 on hard disk samrat_chak1 QnA (read only) 2 26-10-2005 07:03 PM
hard disk problem Techmastro QnA (read only) 1 02-06-2005 11:46 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
