Old 07-02-2008, 11:37 AM   #1 (permalink)
Default Installing XP SP2 on SATA II??
I will be purchasing 250 GB SATA II HDD today.
Ive heard there are quite a few issues installing WINXP on SATA drives.
I will be uisng only this SATA drive has my HDD.
My MOBO is Gigabyte GA-MA69VM-S2 ATI Radeon. 690 V chipset.
Will the XP installation automatically install it on the SATA drive? Will the BIOS or chipset help the installation to automatically install.
can some one please enlighten with what I require and what will be needed to be done to install it.
krinish is offline
Old 09-02-2008, 08:59 AM   #2 (permalink)
Gizmo Freak !
spitfire's Avatar
Default Re: Installing XP SP2 on SATA II??
if you have sp2 slipstreamed xp then you will not face any problem. Drive will be recognised automatically.
but if you hav a vanilla xp then you will hav to install drivers through floppy.
spitfire is offline
Old 09-02-2008, 11:59 AM   #3 (permalink)
Nav11aug's Avatar
hey, i have a Barracuda 80 GB SATA II ... no probs whatsoever with XP with SP2
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 12-02-2008, 06:06 PM   #4 (permalink)
i just installed 160 gb sata II hard disk yesterday
i didn't have any prob with xp2 either
too_techy is offline
Old 12-02-2008, 06:20 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Go ahead and install winnxp SP2, you should not face any problem. If you get any problem, let us know.
ravi_9793 is offline
Old 12-02-2008, 08:10 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
There should not be any kind of problem.
Even I've installed winxp sp2 integrated on seagate 80 GB sata2 HDD with my nvidia 650i ultra based mobo.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 12-02-2008, 08:18 PM   #7 (permalink)
-----ATi-----
nvidia's Avatar
Where did you hear that anyway?? And what kind of issues?
I use Windows XP2 on my 320GB SATA2 HDD.. No problem at all..
http://twitter.com/akshayms
nvidia is offline
Old 13-02-2008, 12:05 AM   #8 (permalink)
The Frozen Nova
casanova's Avatar
Me too din't face any problems. But of my friends XP shows his HDD as a removable drive.
www.nerdweed.blogspot.com
casanova is offline
Old 13-02-2008, 05:26 AM   #9 (permalink)
r2d2's Avatar
^^ sata hard drives support hot swap thats why they are shown as removable drives.
r2d2 is offline
Old 13-02-2008, 06:49 AM   #10 (permalink)
The Frozen Nova
casanova's Avatar
Then why doesn't it show for me as a removable drive.
casanova is offline
Old 13-02-2008, 11:43 AM   #11 (permalink)
r2d2's Avatar
^^ some older sata controllers doesn't suppport hot swap, so that may be your case.
Haven't tried this but sata hot swap can be disabled for nforce motherboards, see this link
http://www.nforcershq.com/forum/wed-...-vp561642.html
r2d2 is offline
Old 13-02-2008, 12:28 PM   #12 (permalink)
-----ATi-----
nvidia's Avatar
I think the hot swap feature requires you to install some drivers...
nvidia is offline
installing redhat 9.0 in SATA says no harddisk asdfgh2 Open Source 1 16-05-2007 06:26 PM
Installing WinXPPro on a SATA HDD debopriyo Software Q&A 11 04-08-2005 10:39 PM
Problem installing OS on AMD64 with SATA coolpepe CPU / Motherboards 3 23-06-2005 12:22 PM
Problem installing SATA HDD icecoolz QnA (read only) 4 10-04-2005 08:39 PM
Trouble installing Win XP in SATA lywyre Software Q&A 3 10-02-2005 01:23 PM
