06-02-2008, 09:53 PM
What if the PC is not well grounded/earthed..
Hi guys
My friend bought a second hand PC around 3months back..and there is no earthing in any of the electrical point at her home.
so any idea on how bad it can get? Is it going to affect the internal devices (hdd, proc, mobo etc.) ? and any problem if she connects a pendrive ?
she even talked to some local electrician and even he wasnt very sure about the "ill-effects" .
Thanx
06-02-2008, 09:59 PM
Re: What if the PC is not well grounded/earthed..
You may get shocks from all the metallic components(including ports like serial/USB port) of your computer if its not properly earthed. It may slowly harm devices as well .
06-02-2008, 10:09 PM
yea i could feel the shock on touching the cabinet !!
and any potential risk in connecting pendrive or "laptop hdd in usb casing" ?
06-02-2008, 10:11 PM
yes. due to current, the device could die.
KDE on ArchLinux
06-02-2008, 10:20 PM
TheSaint
Everything will fail, probably the hard disk or processor first. I was told that if one cannot get earthing, an isolation transformer helps. Please consult an electrician of PC service centre.
And do read this, it is interesting
http://www.thailandguru.com/groundin...lectrical.html
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
07-02-2008, 04:41 PM
*Unlimited&Ultimate*
Originally Posted by Jags
Hi guys
Thanx
ur PSU  and HDD  may get faulty in the future
07-02-2008, 06:10 PM
Yup, surelly HDD will get damaged...nd mabe u wont get proper warranty in case of improper power.
G3: XPS M1530 |
FZ 16.
08-02-2008, 06:55 AM
Norms Buster
It will blow your PSU, MB, HDD etc....
Don't procrastinate on grounding.
08-02-2008, 07:10 AM
Zor Ka Jhatka Dhire Se Lagega..
earthing karva lo....
Zindagi Toofani Hai... Jahan Hai DuckBurg!
08-02-2008, 08:53 AM
nahi bhai.
Dhire ka jhatka jor se laga
Reason: Little Current damages your HDD, Mobo, almost everything
Samjhe ??
KDE on ArchLinux
08-02-2008, 06:23 PM
^^haan woh to main samjha  ..
lekin Jhatka to lagega hi
08-02-2008, 07:02 PM
damn busy...
Mirinda pee lo
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
08-02-2008, 08:46 PM
Fast 'N' Furious
It may reduce ur component life
But my old rig was not earthed when I bought it & using 3 years ago. I've used that pc for eight long months without any probs except a little shock.
After eight I've earthed my electricity line properly  . I am using that pc still now with all the old parts & some upgraded parts.
09-02-2008, 12:46 AM
Romeo + Lucifer = ME
Prevention is better than cure
der se hi sahi bhai......earthing karwa lo
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
09-02-2008, 11:59 AM
As others have rightly mentioned, all components will be prone to failure and the first will be the HDD. At least get the PC's plug point earthed and get it checked using a DMM and not as is usually done by electricians using a bulb.
After all it will not cost you much if you are not staying in a high rise building.
V.Prem Kumar
11-02-2008, 03:04 PM
hmmm..
bomb's ticking.. thanx everyone
11-02-2008, 03:17 PM
damn busy...
Ur avatar luks like a bomb
www.techjunkiez.com
12-02-2008, 07:37 PM
Fast 'N' Furious
 Cabage Frog Bomb
12-02-2008, 07:45 PM
#19 (permalink)
Nothing will really happen if the machine is not grounded other than getting those mild shocks if you touch it. I've had a P3 running without grounding for all its life before I sold it (i.e. 3 years).
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
12-02-2008, 07:54 PM
#20 (permalink)
TheSaint
You said it
Those old processors were slower and less prone to power problems unlike the latest fast processors. Try using a new rig without earthing, you won't get very far, I assure you.
12-02-2008, 07:57 PM
#21 (permalink)
left this forum longback
I had lost my mercury 810e board back in 2000 due to bad earthing
now I have made a dedicated earthing for my pc .
BTW,what about laptops  !I hope dc will not kill you!
when in lap it will fry ur *alls thats all na?esp apple mbp's
thank god I dont have one now
13-02-2008, 01:04 AM
#22 (permalink)
Originally Posted by NucleusKore
You said it
The rig in my sig had no earthing for a couple of months as my home's earthing was borked. Its now fixed though. Again no issues other than a few little shocks here and there.
Lack of earthing can't kill a machine as beyond the power supply, there is no AC anyway. At most the PSU can get die assuming the PSU has proper output filtering.
13-02-2008, 04:07 PM
#23 (permalink)
Rising ApocalypsE
Hey there not always disadvantages for "not" having earthing!
U can enjoy someone gets shock while u sits in the corner!
Just Kidding! But one should always consider it for happy and long life of your hardware!
