Old 05-02-2008, 03:10 PM   #1 (permalink)
Default trouble with my PC to connect net with BSNL Broadband Modem- reg
hi experts here,
let me discribe my problem,
that, i m using BSNL braodband, in my office. but now, cant connect net with this. One BSNL Man came and checked my PC. he says that, this is the problem of my PC. but i was not there at that time. and afterwrd, have checked. cant found any error with even usb port.
i am thinking that, this will be the problem of any settings.
also to say u that, i m using Win Xp.
can anyone guide me pls
thanking you in advance
wt lov
mobileman
mobileman is offline
Old 06-02-2008, 04:22 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: trouble with my PC to connect net with BSNL Broadband Modem- reg
Please check if there are any loose conections between the splitter and ADSL Modem.
techtronic is offline
Old 06-02-2008, 11:13 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
1) connect modem to your PC.
2) see, if all lights on the modem are blinking.
3) Check IP setting of the LAN card.
4) PIng 192.168.1.1 and post back result.
ravi_9793 is offline
Old 06-02-2008, 07:31 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
@ mobileman
can you elaborate more on this prob ? Like what error message you are getting or what is exactly happening when try to connect to the net ?
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Modem settings for BSNL broadband nil_3 Networking 3 20-03-2007 07:15 PM
BSNL broadband modem Help Stalker Hardware Q&A 10 06-08-2006 04:59 PM
