Old 05-02-2008, 11:12 AM   #1 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Question Unrecognized usb device!!!! Any Solution!!! PLs
Hi Guys,
I have several usb devises like, Data Cable,,MMC Reader,,etc..
Whenever i try to connect some of them to my PC It Gives me
A message out like "Unrecognized usb device" Wat the hell this.
Is there any solutions for this Problem...
Thanx In Advance.......
Orionz is offline
Old 05-02-2008, 12:04 PM   #2 (permalink)
Norms Buster
Default Re: Unrecognized usb device!!!! Any Solution!!! PLs
Try different USB Ports especially the rear ports.
Some devices which won't work in one USB port will work in another.
VexByte is offline
Old 05-02-2008, 12:14 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Possible cause:
1) Device is not properly connected.
2) USB port or device port or cable is damage.
Try your cable on other computer. Than post back result.
ravi_9793 is offline
Old 05-02-2008, 11:08 PM   #4 (permalink)
Orionz's Avatar
Unhappy Re: Unrecognized usb device!!!! Any Solution!!! PLs
Originally Posted by ravi_9793 View Post
Pos....
...Try your cable on other computer. Than post back result.
Not all but some are woking on My Friends PC...
Orionz is offline
Old 06-02-2008, 06:01 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
Time to format and reinstall your old OS or try Linux.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
How to connect a usb device which the win xp says as UNKNOWN DEVICE? aQi_g Software Q&A 8 03-07-2008 03:59 PM
need a solution Saharika QnA (read only) 2 25-07-2007 12:27 AM
Need of solution kumarn_2004 Software Q&A 2 19-09-2006 10:56 PM
Which is the better 64-bit solution? a_to_z123 QnA (read only) 9 06-12-2005 07:47 PM
