Old 03-02-2008, 08:07 AM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default Hard disk quarry...!
I have 2 segate sata hard disk, 80 gb each and both are connected to my pc and one has a 4 partition which is installed with vista and other has two partition but no OS is there..
now in my bias both the hard disk is showing as master, but my pc is running ok taking more time at start up... after that it is ok...
now my qsn is is it necessary to make the 2nd hard disk slave and the 1st one as master....?
My TeCh Blog: Gtechinfo
>> http://gtechforall.blogspot.com
Mobile Blog : Gtechmobiles
>> http://gtechmobiles.blogspot.com
gau_pppu is offline
Old 03-02-2008, 08:13 AM   #2 (permalink)
The Unknown's Avatar
Default Re: Hard disk quarry...!
You need to change the jumpers of the hard disk. You'll need to open up your box and see it. If you don't know, consult your vendor.
KDE on ArchLinux
The Unknown is offline
Old 03-02-2008, 08:36 AM   #3 (permalink)
Attitude matters
Ponmayilal's Avatar
My understanding is that SATA drives do not go by master/slave configuration. Now I'm confused
Ponmayilal is offline
Windows Vista quarry.! gau_pppu Software Q&A 2 03-02-2008 11:01 AM
PayPal quarry chicha QnA (read only) 11 22-01-2008 05:24 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
