Old 01-02-2008, 11:50 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Wink Yet another Seagate, Failed & replaced
Hi digitans,
I purchased a Seagate ST380817AS 80 GB SATA-I on may 05, it failed on june 06 & then replaced it with a Certified Repaired HDD. then again recently 20 days back. it failed again, this time i ensured i got a new drive
Damm this Seagate
so i got a 7200.10 SATA-II drive but i tried installing Windows xp on it but it failed. http://www.seagate.com/ww/v/index.js...D&locale=en-US
so please help me install windows xp
gary4gar is offline
Old 01-02-2008, 11:52 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Yet another Seagate, Failed & replaced
what error are you getting?
Charan is online now
Old 02-02-2008, 12:39 AM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
hardware not found :S
my mobo is: MSI k8mm-v
gary4gar is offline
Old 02-02-2008, 02:43 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
@gary4gar - When I browsed the MSI Site for your MB's Tech Specs, it indicates RAID 0 & RAID 1 support. Try disabling the Onboard RAID Controller and then try to install Windows XP. Update me after trying this.And regarding Seagate SATA Drives, I had a bad experience of 4 of my newly replaced HDDs getting bad sectors as early as 10-15 days.
techtronic is offline
Old 02-02-2008, 01:34 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
okay
gary4gar is offline
Old 03-02-2008, 02:54 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
there is no option to disable Onboard RAID Controller, however i tried disable Onboard SATA Controller but this didn't help
I think i need to integrate SATA drive in Xp
gary4gar is offline
Old 03-02-2008, 03:40 PM   #7 (permalink)
prasad_den's Avatar
^^ YEp.. ypu need to either do that or disable AHCI support for SATA in your BIOS..!
prasad_den is offline
Old 03-02-2008, 03:46 PM   #8 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Try to find which SATA controller is on the HD. Based on that, you can integrate the drive for your Windows. I have been doing that all evening yesterday
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 03-02-2008, 04:40 PM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
how to find?
gary4gar is offline
Old 04-02-2008, 03:40 AM   #10 (permalink)
techtronic's Avatar
http://www.richandstephsipe.com/word...n-motherboard/
This would help you with your installation although I do not know what motherboard are you using.
Old 04-02-2008, 10:05 AM   #11 (permalink)
GaurishSharma.com
gary4gar's Avatar
but how do i slipstream?, no windows here
gary4gar is offline
Old 04-02-2008, 10:08 AM   #12 (permalink)
prasad_den's Avatar
Then a floppy drive would be a better option..! Did you try disabling AHCI? It should work that way, but you'll end up losing the advantages of SATA.. which are negligible in any case...!
Samsung or the Seagate HDD ! My Advice---Seagate is better. dabster Hardware Q&A 14 29-12-2008 08:12 AM
Can Nokia Joystick be replaced? He28 Mobiles and Tablets 4 26-07-2007 10:21 AM
Bill Gates Replaced as the Richest Man in the World. anandk Technology News 12 05-07-2007 11:55 PM
WinXP-SP2 files replaced....help linardni Software Q&A 2 04-11-2006 05:05 PM
