Originally Posted by satyamy
can you tell more details about it ?
The following threads will help enlighten you:
How good is this system?
Big Apple computer for 6995/- only
ofcource, if you need to run windows 98 and don't want historicware, you can look at this
configuration:
AMD Sempron AM2 3000+
Specs:1.6GHz, 256KB L2 Cache, 800MHz FSB, 90nm, Enhanced 3D Now!, NXBit, AMD64
Price: Rs.1,650/-
MSI K9MM-V -
Specs: VIA K8M800, AMD Athlon64 X2/Athlon64/Sempron, Socket 940 AM2, 2GB DDR2 533/667/800MHz, 1GHz FSB, SATA RAID, Realtek ALC655 5.1ch Audio, 10/100Mb Ethernet, AGP 8x, mATX
Rs.1,650/-
Transcend JetRam 1GB PC2-5300 -
Size: 1GB DDR2 667MHz
Latency: 5-5-5-18 (CAS,tRCD,tRP,tRAS)
Function: Unbuffered
Operating Voltage: 1.8v
Warranty: Lifetime
Rs.900/-
The Set as you see will cost Rs. 4200/-, that being the maximum price as the indivudual components may be even cheaper.
And it can run Windows XP, common distros, and windows 98/2000 comfortably.
