Old 31-01-2008, 12:17 AM   #1 (permalink)
adit_sen's Avatar
Default New System Wont Boot
I just put together a system with old parts I acquired from a friend. Its an AMD 3800 64, 2GB RAM, and a WinFast PX6800GT PCI-E Graphics Card. Now when I boot, every thing seems to run normal, except that there is no display on the screen. The graphics card seems to be running (gpu fan is spinning), but there is no output
1. could there be an issue with the dvi to vga connector? i'm using an old crt monitor and the card has no vga outputs
2. i've noticed a 6pin power supply on the card, but i didnt get any cable for that. would i need the power cable? can't PCI-E cards power up using the motheboard power itself?
cheers
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 31-01-2008, 10:13 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: New System Wont Boot
^^^ get urself a new psu cuz ur card wont workwith ur present psu.
also make sure that the new psu has the 6-pin pwr adapter.
hellgate is offline
Old 31-01-2008, 10:24 AM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
Smile Re: New System Wont Boot
And also buy only a 400 W PSU.
Stealth mode, I like that. Kool.
Blogging at:
A Techies Blog
saqib_khan is offline
Old 31-01-2008, 06:14 PM   #4 (permalink)
adit_sen's Avatar
I have a 450W PSU. Also, on testing on another mobo, the card worked fine (without a 6-pin power cable)...
what else could be the problem?
adit_sen is offline
Old 01-02-2008, 02:15 PM   #5 (permalink)
if there is a 6 pin connector on your cards then you must connect it in order for it to work properly..just forget about it working on another motherboard...
buy a coolermaster 600W for around 3600 to guarantee that it will work not only on your current old system but also on future system you may upgrade to...
realdan is offline
Old 01-02-2008, 06:14 PM   #6 (permalink)
pratik03's Avatar
you don't need to change your power supply you just need 4-pin to 6-pin molex power adapter
after connecting it your computer should boot normaly
pratik03 is offline
Old 01-02-2008, 11:08 PM   #7 (permalink)
adit_sen's Avatar
ok guys, tried the power cable for the card, and it still has the same problem. any other ideas?
adit_sen is offline
Computer Wont Boot Up Demonkiller Hardware Q&A 7 08-08-2007 07:08 PM
machine wont boot! jambay19 Hardware Q&A 1 28-07-2007 07:42 PM
help: PC wont boot :(( Jags Software Q&A 3 29-04-2007 11:12 PM
System cannot find system disk during boot. sushantasarkar Hardware Q&A 1 04-02-2007 10:05 PM
System wont boot.......fdisk wont work.......xp wont install irradiated_chicken Software Q&A 10 10-06-2005 10:50 AM
