Old 29-01-2008, 04:02 PM   #1 (permalink)
New
New's Avatar
Default How to OC E4500?
Hi friends...Please tell me how to OC E4500 with Intel DG33motherboard..
New is offline
Old 29-01-2008, 04:21 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: How to OC E4500?
Sorry to inform you that Intel DG33xx boards do not support over clocking
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-01-2008, 05:32 PM   #3 (permalink)
New
New's Avatar
Choto sir I am not getting good performance from this E4500 in vista home premium..What's the solution?
thanks..
New is offline
Old 29-01-2008, 07:49 PM   #4 (permalink)
Multicore Mutant
What a mistake ? You should have gone for e4300 , and other mobo instead of Intel. Intel mobos are also not so reliable nowadays. On the other hand Asus boards are very stable at ocing(which reflects their strong build quality). BTW You can oc e4300 to a max of 3.6ghz IIRC.
Hackattack is offline
Old 29-01-2008, 09:30 PM   #5 (permalink)
Rebooting
@New
this is a real subjective question i mean u cant compare that system with a E6xxx system or a Q6600 system
what makes you think the system is under performing comparing with a same range system ??
rebooting
ChotoCheeta.com
Old 29-01-2008, 09:56 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
i've e4500 on dg965wh m/b, & runnin Vista Ultimate, there's no slowdown, or anything like that.
btw what RAM you have?
i'm having 1GB RAM (512x2) running @800MHz.
__
s18000rpm is offline
Old 29-01-2008, 10:28 PM   #7 (permalink)
New
New's Avatar
@Choto
Sir I have come to this decision as one of my friends PC runs smoother than mine with P4 3Ghz...
@s18000rpm
I am using Transcend 2GB RAM(800Mhz).
New is offline
Old 29-01-2008, 10:34 PM   #8 (permalink)
a_g = JPKN
s18000rpm's Avatar
make sure they're running at 800MHz .
btw have you installed them in dual channel mode?
--------[edited]--------
just saw your sig
as you have 2 HDD's, what SMPS (PSU) [wattage] are you using?
& if you've windows XP, then does it run well?
make sure you've latest drivers/bios...
http://downloadcenter.intel.com/defa...pport_Download
__
Old 29-01-2008, 10:49 PM   #9 (permalink)
New
New's Avatar
How can I check whether my RAMs are running at 800Mhz?
Yes,I have installed it in Dual channel..
I have 250W Bentec PSU and XP works with no problem...So I am planning to install
Vista Ultimate once.
Thanks..
New is offline
Old 29-01-2008, 10:55 PM   #10 (permalink)
damn busy...
utsav's Avatar
I think the 40GB hdd is old and is a bottleneck for the system if its running in pio mode
Man u rock u r running that pc with a 250w psu !!! .get a 400w psu atleast even the 400w ,450Rs zebronics psu will be fine
MSI GX660 with ATI 5870 ultimate gaming lappy
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 29-01-2008, 11:01 PM   #11 (permalink)
New
New's Avatar
Ya..I am running on 250w PSU..Will bring new PSU only when it expires as I think it will not improve performance of the PC
New is offline
Old 29-01-2008, 11:17 PM   #12 (permalink)
Rebooting
@New
get any local 450 watts at Rs. 400/- will do better
also install the OS at SATA HDD or 160 GB and keep the page file at the 40 GB PATA will give better performance
rebooting
ChotoCheeta.com
Old 29-01-2008, 11:24 PM   #13 (permalink)
New
New's Avatar
Thanks for the suggestions..
My 40GB HDD is also SATA...Sir, I will definately bring one PSU within a week..
Thanks...
New is offline
Old 29-01-2008, 11:30 PM   #14 (permalink)
Rebooting
use the CCleaner move the page file to another drive... defrage the HDD... use an AVS make sure system is malware free... keep the system uptodate
rebooting
ChotoCheeta.com
Old 29-01-2008, 11:49 PM   #15 (permalink)
New
New's Avatar
^Thanks for the advice...Can you tell me how to check whether my RAMs are running at 800Mhz?
Thanks...
New is offline
Old 29-01-2008, 11:53 PM   #16 (permalink)
Rebooting
please download CPU-Z run and post th screenshot (of all its tabs) here
http://www.cpuid.com/cpuz.php
rebooting
ChotoCheeta.com
Old 29-01-2008, 11:57 PM   #17 (permalink)
New
New's Avatar
Will do it right now...
New is offline
Old 30-01-2008, 12:11 AM   #18 (permalink)
New
New's Avatar
It's here
New is offline
Old 30-01-2008, 12:20 AM   #19 (permalink)
Rebooting
it is running Dual Channel and 800 MHz note its DDR so as CPUZ reports 400 MHz clock so actuall speed 400x2
rebooting
ChotoCheeta.com
Old 30-01-2008, 09:02 AM   #20 (permalink)
New
New's Avatar
Thanks Choto
New is offline
Best value for money mobo for C2D E4500 ! writealexthomas Hardware Q&A 60 01-04-2008 09:26 PM
Which MOBO for Core2 E4500?? Ganeshkumar Hardware Q&A 9 22-11-2007 11:13 PM
