| Forum |
#1 (permalink) |
D i s t i n c t l y Ahead
My Samsung Cd Writer tray is not coming out on Pressing the Eject button So i have to insert a pin on the small hole given to bring the Cd tray Out The Cd writer is out of Warranty . Plz suggest me What can be done Now ? |
#2 (permalink) |
Ðèåd Måñ Wå£KîÑG
First, basic reason can be Dirt. Open the CD tray through the pin and try some manual in-out movement. Then give it a natural glow, by pressing the "Eject" button....
Is still facing issues, check the following - Locking device / software installed - First, verify no locking software is being loaded which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive - If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Bad eject button - If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. Incompatibility with IDE / ATAPI interface - If you are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive - Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. It is not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution.
Once the game is over, the King and Pawn goes to the same box.... Last edited by bad_till_bones; 26-01-2008 at 07:14 PM. Reason: Automerged Doublepost |
#3 (permalink) | |
Alive Again...
the only thing you can do is, remove your writer and give it to some hardware repair shop and tell them to repair or buy a new DVD-Writer for rs. 1250/-
! जय हिंद ! Proud to be INDIAN |
#4 (permalink) | |
eject
KDE on ArchLinux PHP, MySQL, PostgreSQL, Linux, Apache; Message me to hire (freelancing only) Explore Technology @ http://www.itech7.com Cheap and Reliable VPS Hosting @ http://j.mp/arHk5e |
#6 (permalink) |
IT happened with me as well and then i have replaced the same. The best option is to go for a new one. The chances of getting it ok is very less.
Technology On The Fly |
#7 (permalink) | |
#9 (permalink) | |
Elevating Humanity
Regards, The Conqueror |
#10 (permalink) | |
damn busy...
MSI GX660 with ATI 5870 Dell Studio 15(1555) 1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+ www.techjunkiez.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| speakers are not working properly | vicky_l7 | Audio | 3 | 30-09-2007 11:31 AM |
| pc cd writer tray keeps coming out | gramesh | Hardware Q&A | 1 | 21-01-2007 12:12 AM |
| DVD writer not working properly | blacklisted | Hardware Q&A | 12 | 31-07-2006 10:40 AM |
| Solution for Samsung CD-RW Drive tray problem | sms_solver | QnA (read only) | 8 | 25-03-2005 10:39 PM |
