Old 26-01-2008, 01:43 PM   #1 (permalink)
Default Sony AW-G170A
I got the Sony AW-G170A (firmware 1.62) and I am getting the power calibration error while burning DVD-R using nero 7, it burn OK with CD.
The DVD-R brand is Verbatim.
SMPS: Corsair HX620
I connected one 4 pin cable directly to the dvd writer
On further check, the retail box that i got along with this drives is branded as Sony DRU-170C DVD+/-R 18X.
I m looking to update the firmware..but so far didn't find a suitable one..
Yeah and i have tried the suggestion provided in the archive but it wont work
Anybody facing the same problems? anybody have any idea?
or I have to return it..for claiming warranty...if i can solve then i dont want to go through the hassle of that
realdan is offline
Old 27-01-2008, 02:04 AM   #2 (permalink)
Default Re: Sony AW-G170A
update:
i got a sony DVD+RW and managed to burn a multi-session disc. However i couldnt see any content on it using the dvd drive...then i check the disc in another PC and found the files that I have written and the file is working fine...
realdan is offline
Old 27-01-2008, 10:16 AM   #3 (permalink)
yes i have faced same issues in the past. i guess its just hereditary for tht sony drive.
when i tried to get it repaired, i had to send it to rashi peripherals atleast 4 times because they just cudnt understand the problem. atlast they replaced it wid another drive.
but yea, they were saying tht there is a prob wid firmware of such drives..
varunprabhakar is offline
Old 27-01-2008, 09:53 PM   #4 (permalink)
i flash it with the firmware version 1.73...
same issue...
in fact it cannot read burnt dvd disc...it can read the movie dvd, digit dvd...
isobuster show the content of the disc and i can extract the content
nero info tool cannot show the size of the disc and show only the title
dvd decrypter said empty disc
nero burning rom 8 show the disc as empty
windows explorer cannot detect the disc..asking me to insert disc
realdan is offline
Old 01-02-2008, 02:24 PM   #5 (permalink)
The driver detected a controller error on \Device\Harddisk0\D.
D is my dvd drive
realdan is offline
Old 01-02-2008, 02:46 PM   #6 (permalink)
Maximum Fame
quadroplex780's Avatar
If u have an ide drive attached along with the sata drive(HDDS)then disable the ide hdd and see if the Sony drive reads the writed DVDs
ASUS P5N32E-SLI,XFX 8800GTS 640MB SLI,Intel Core 2 Duo E6600 Oced @3.01Ghz,Thermalright Ultra 120eXtreme,Corsair HX-620W PSU,250 GB Sata Seagate & Sony Sata AWG170S DVD writer,Asus Supreme FX Audio.
quadroplex780 is offline
Old 02-02-2008, 01:51 AM   #7 (permalink)
i have sata hdd and ide sony dvd drive
from what i see elsewhere...this particular range of drives from sony is really bad...this is the sixth months that i have had the drive...with very rare burning so far..since this is a new pc and there are plenty of space in my hdd so didnt bother about burning much
looks like it could be half dead?
realdan is offline
Sony Ericsson W850i vs. Sony Ericsson K800i (Walkman vs. Cybershot) soumya Mobiles and Tablets 10 03-10-2008 02:23 AM
Problem reading DVDs written by SONY AW-G170A joy.das.jd Hardware Q&A 5 26-04-2008 11:14 PM
==> Sony PSP <== prathamtawde QnA (read only) 8 19-10-2007 09:28 AM
Which dvd-writer sony dw-q120a or sony dru-820a its urgent anirudhasarawgi Hardware Q&A 3 27-05-2006 05:47 PM
