Old 25-01-2008, 11:09 AM   #1 (permalink)
Default System Hangs on using USB device
Hi, I am having a p4 based pc using intel d845gvad2 mobo. on 2 seperate partitions of the hdd i have win98 & win-xp installed. whenever i tried to attach a pen drive or mobile on a usb port, the system hangs. i tried to use the pendrive by installing appropriate drivers in win98 also but the problem remains. kindly suggest remedies.
regards.... bye... ashish
ashish1307 is offline
Old 25-01-2008, 06:16 PM   #2 (permalink)
Default Re: System Hangs on using USB device
Does this problem appears in XP? I am facing this problem in XP since few days. I also created a thread to ask for assistance but I got no reply.
Does any body else facing similar problem?
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 25-01-2008, 07:03 PM   #3 (permalink)
Ðèåd Måñ Wå£KîÑG
bad_till_bones's Avatar
chk this -
  1. Reboot (or power on) system.
  2. Press "F2" during POST (Power-on Self Test) to enter system BIOS setup program.
  3. Select "ADVANCED" menu using arrow (left and right) keys.
  4. Select "USB Configuration" and press <enter>.
  5. Enable "High-speed USB".
  6. Press "F10" to Save & Exit BIOS setup program. ( Hi-Speed USB 2.0 controllers are now enabled and your operating system should detect New Hardware during the next normal boot cycle.
  7. Cancel "New Hardware Found".
Once the game is over, the King and Pawn goes to the same box....
bad_till_bones is offline
System Hangs at night!!1 The Day Walker! Hardware Q&A 4 29-07-2007 01:24 AM
System hangs..help linardni QnA (read only) 3 10-02-2007 03:59 PM
search system hangs!! gary4gar QnA (read only) 2 23-02-2006 01:27 PM
HELP!!! SYSTEM HANGS TOO MUCH hsnayvid QnA (read only) 26 21-04-2005 05:27 PM
