Old 25-01-2008, 12:39 AM   #1 (permalink)
.:: 3 : 1 6 ::.
anish_sha's Avatar
Exclamation Urgent help needed pls..
Frenz, i just bought an 80gb LACIE external harddrive, when i'm trying to copy an dvd nero image file of 4.5gb to the external harddrive, i get the error message, "There's not enought free space available on the disk" where as the disk still has more than 70gb of free space.. Pls help me guys.. To solve this problem..
anish_sha is offline
Old 25-01-2008, 01:05 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Urgent help needed pls..
which file system is it in ?? FAT 32 cant have a continues 4 GB file so please make sure the disk is in NTFS file system
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-01-2008, 09:10 AM   #3 (permalink)
Google Bot
Pathik's Avatar
+1. Convert it to ntfs 1st if u want files greater than 3.2gb
Pathik is offline
Old 25-01-2008, 10:39 PM   #4 (permalink)
.:: 3 : 1 6 ::.
anish_sha's Avatar
Thumbs up Re: Urgent help needed pls..
Thank you guys for the help.. I formatted and changed the file system.. It worked.. Thanks.
urgent help needed! amanjagga Programming 6 02-12-2007 03:59 PM
Urgent help needed!!! Harvik780 Hardware Q&A 5 26-07-2007 11:24 PM
Please help me someone.urgent Help needed Harvik780 Software Q&A 5 30-04-2007 06:33 PM
Urgent help needed!!!! bizzare_blue QnA (read only) 2 12-03-2005 09:47 PM
urgent help needed striker_1909 QnA (read only) 7 15-11-2004 11:54 AM
