Old 24-01-2008, 04:19 PM   #1 (permalink)
RiGhT HeRe RiGhT nOw
ashishnehete's Avatar
Exclamation RAM for inspirion6400
What is the maximum ram can dell inspirion 6400 can handle
please give me the specification of the ram to buy frequency all that stuff
which company i should go 4
i want thiss info urgent as my dad will be in lamington road
ashishnehete is offline
Old 24-01-2008, 05:07 PM   #2 (permalink)
Default Re: RAM for inspirion6400
Got this info from the official Website:
Memory
Memory module connector - two SODIMM connectors
Memory module capacities - 256 MB, 512 MB, 1 GB, and 2 GB
Memory type - 1.8-V SODIMM DDR-2
Minimum memory - 256 MB
Maximum memory - 2 GB
You can download the Inspiron 6400 Manual in PDF format HERE.
Hope that helps.
From what I know, you can go in for Hynix / Kingston / Transcend.
Note: I think Inspiron 6400 supports only upto DDR2-667 i.e. PC2-5300. So check that before buying.
shadow2get is offline
Old 25-01-2008, 04:55 PM   #3 (permalink)
i was thinking of buying corsair
is it good what would it cost me for 1GB DDR2-667
is it maximum 2GB per module or whole of 2GB
Old 25-01-2008, 06:07 PM   #4 (permalink)
Hey, I missed Corsair when I was replying to that. Corsair & Kingston are very good in Memory products. You can go for them.
Also, Corsair/Kingston may be costlier than Hynix /Transcend.
Regarding Memory .... The maximum memory you can put in the Laptop is 2GB.
So you would have to go for two 1GB modules.
If needed, You can call up the Dell Customer Care & clarify with themregarding the max memory capacity.
Here is the Price list for 1GB DDR2 - 667 module.
Hynix - Rs. 1350
Kingston - Rs. 1160
Transcend - Rs. 1020
All the above prices are from Computer Warehouse, Bangalore. It will be cheaper in Mumbai, I suppose.
Old 26-01-2008, 10:18 AM   #5 (permalink)
Thanks bro that realy helps
