Re: ..::Broadband Woes::..
ravi_9793 thnx for your elaborate and dedicated reply. I find my speed goes down by looking at my download meter you know some software. And btw I tried wat you gave and it is giving me some timeouts at certain intervals.
And the airtel guy, keeps saying it does not have a problem btw I think its disconnecting bcs the 3rd and 2nd light goes off.
I guess the ping to 192 is to the modem?? if so that has not showed any timeout for 1 hour and for the entire time, I have not found any Decrese in speed in my software too. But for the 2xx one, I found timeouts.
www.harivarrier.com
Check out to earn money...
