Old 22-01-2008, 12:09 PM   #1 (permalink)
Be urself--->
karina_got_it's Avatar
Default hi.. query regarding ASUS m2a-vm
Hey i got asus m2a-vm mobo recently. the reviews i read said it takes 256mb from RAM for graphics.. ll it take automatically.. or i have set it.. plz provide info for that..
karina_got_it is offline
Old 22-01-2008, 12:47 PM   #2 (permalink)
harryneopotter's Avatar
Default Re: hi.. query regarding ASUS m2a-vm
by default it will share 64 mb from ram ....
to change it .. u have to go to bios setup and change it from there.
start the pc ...
press "del" when bootscreen comes up to go to setup ..
Goto the second menu option on top (Advanced)
then the from option (Chipset)
then change the second option (Frame buffer size ) to the required value (16 MB, 32 MB, 64 MB,
128 MB, 256 MB) .. according to ur requirement .....
hope it helps ...
harryneopotter is offline
Asus A8V-MX yoursnayak Hardware Q&A 1 16-10-2007 02:21 PM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600 ?? rachitboom2 QnA (read only) 1 07-03-2005 02:32 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600!!! rachitboom2 QnA (read only) 1 06-03-2005 04:05 PM
