i was going thru the overheating thread and i downloaded cpucool.when i started the program,i got an error message(attatchment below).whats the problem,is it serious and how can it be fixed
The problem might get worse. How old is your disk? First, do a thorough check up of the drive using tools from Seagate or Western Digital. If it is under warranty, try to get it replaced. Start backing up NOW!
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
